Notebook dell latitude c610 how to repair broken hinge pin screws broke where the screws enter the pin hole in the base and holds the bottom of the notebook left 1 pin and 2-pin right in inverted u hinge and up toward perfect lcd screen
Go www.dell.com give your service tag, model and download your instr. manula and service manual , parts and fix it.
God bless you
SOURCE: dell latitude c610 has dead screen.
First of all, try to connect an external monitor to the laptop and see if you gen any video out.
SOURCE: dell latitude c610 touch pad left button problem
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
SOURCE: Dell Latitude C610 PC Notebook pct2304wt modem driver
Hi!
You can find a driver for your modem and all other drivers on this site:
http://www.drivershq.com/Drivers/Dell/Latitude/C610/11/224/238/Drivers.aspx
Cheers!
The modem driver can be found at this link. try the PCTel driver first, more than likely that's the one it uses.
Lolita
SOURCE: no sound from dell latitude c610 notebook computer
You usually fix the cood11ba problem reinstalling the sound driver for this laptop.
Sound drivers for this model can be downloaded entering model number on page below and following instructions:
Dell Drivers and Downloads
