Where can I find an electrical schematic
See this causes and fix it. God bless you
If the vacuum cleaner motor doesn't run the on - off switch might be
turned off or defective. Test the switch with an Ohm meter or continuity
checker.
If the vacuum cleaner motor does not run the motor itself might be
burned out. Check the power switch first to be sure the motor can get
power. Then, be sure the motor shaft can turn freely, that nothing is
obstructing it. If the motor can turn freely and is getting power but
still won't run it will need to be replaced.
SOURCE: Beater Bar Does not turn
Also the beater bar only works when the handle is in the operating position. Meaning the foot release must be depressed and the handle tilted back towards the user.
SOURCE: beater bar motor will not engage
Check your clutch to make sure it's engaged. There should be a knob on the foot of the vacuum that can be turned to stop the roller.
SOURCE: Beater Bar Quit Working
Its highly unlikely you'll get a free answer on this web-site, so it's either fork over the money to these jokers or get an answer for free on another forum.
SOURCE: roller motor on a DC17 dyson wont turn on
there is a reset button under the cover that houses the on/off switches. remove the handle/wand and look on the back (where the top of the hose sits) for 2 screws (its a torx/star head screw size t10 i believe). remove them and locate 4 small locking tabs that hold the switch cover to the frame of the vacuum. Depress them and pop the cover off (2 towards the top and 2 towards the bottom). Youll see 3 switches (2 square red buttons and one small cylindrical shaped one). Push the small red one (the one to the left if my memory serves me right). you should hear a click. if you do than the switch is reset. if not check all connections to all 3 switches. if you see nothing loose or not connected, you may need a new brushbar motor. try it
