Was working fine. Bag isn't full. Motor runs.
See this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air
filter might be clogged. Remove the filter and either clean or replace
it as needed.
Exhaust Filter
If the vacuum cleaner won't pick up and has
no suction the exhaust filter might be clogged. Remove and clean the
filter, replace it if its torn or damaged.
Vacuum Hose
no suction the vacuum hose might be clogged. Remove the hose from the
vacuum cleaner, stretch it out straight, shine a bright flashlight in
one end and try to see light through it. If no light can be seen, use
something to run through the hose and free up the obstruction.
Vacuum Bag
no suction the vacuum bag might be full. Clean or replace the bag as
recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup
assembly might not be installed tightly, or it might be cracked or
broken. The dust cup must seal tightly in order to produce the right
amount of suction. If it is cracked or broken, replace it. Most glues
and adhesives will not successfully seal the crack.
Blower Wheel
If the vacuum cleaner won't pick up and there
is no suction, the blower wheel might be jammed or broken. Check the
blower wheel to be certain it turns freely. If it doesn't, check to see
if there is anything rubbing against it. If not, but it's hard to turn,
the motor is most likely the problem.
SOURCE: Durt Devil upright 12 amp Vision Vacuum Cleaner
If there no blockages in the hoses, then the next thing to check would be any filters in the vacuum. When these get clogged, you will experience this problem.
Dave
SOURCE: Hose has very little suction
ok dont know but if you havent already where the roller sits underneath it where the dirt sucks threw i had a problem a little like yours i did every thing you did same thing happened.but i had a clog in the vacuum i used a pressure with out the dirt canister on i blew out a real nice hairball.after that i tried it and what do you know it worked. hope that helps
SOURCE: I have the Miele cat & dog S5000 vacuum. I
Greetings,
I would say that you have a slight clog in the hose or in the power nozzle somewhere. The full bag indicator is just a guage that will indicate full when it feels like it's lost suction. Example: If you were to take the hose and cover it with your hand, you'll notice that bag full indicator will show full.
To check and see where the clog in the vacuum is, remove the wands and floor attachment so you just have the hose on the vacuum cleaner. With just the hose attached, turn the vacuum cleaner on. Does it still show a full bag? If yes, then remove the hose completely from the vacuum cleaner so it's just the canister part by itself and turn on the vacuum again. If the bag full indicator is now showing an empty bag, this means that you have a clog in your hose.
If the bag full indicator displayed an empty bag when you had the hose on the vacuum, but shows a full bag when you have the wands and floor tool attached, this means that you have a clog in the vacuum either in the wands, or the floor attachment.
For removing clogs from the hose, the quickest way is to just purchase a plumbers snake at your local hardware store, and run the snake through the hose until you find the clog. You may also take a high pressure hose and spray it down the hose until the clog is cleared, but if you use a water hose, MAKE SURE the hose is 100% dry before you use it again.
Also that bag full indicator can be adjusted if you are getting a lot of suction power and it still shows full.
I hope that these suggestions helped you diagnosis your Miele canister to figure out why the indicator showed full. If this helped you please rate my repair helpful.
Feel free to contact me if you need further assitance, I'm always happy to help.
Chris J.
SOURCE: Electrolux model 2100 shuts off with slightest suction blockage
This is exactly the symptom you would expect from a defective bag control valve. The actual control valve sits under the dial on top of the vac and often cracks internally. It can be replaced in about 15 minutes by a good tech with genuine parts from AERUS Elctrolux dealer or repair center.
You can open the vac front to rear like a **** shell by sliding the bumpers out the front with the bag door open, however you must be careful not to disturb the wiring harness and to mark wiring locations. The body must be carefully realigned for closure. If it is not perfect you will not be able to slide the bumpers back in.
SOURCE: miele vacuum cleaner not working properly
Is the suction low or ok at the vacuum without the hose attached? If it is ok, then there is a clog in the hose. If it isn't, then check filters, is the speed variable, is the contol set too low. Could be a bad motor, running too slow.
Thank you so much for the replies,very helpful. I'll check the filters now. I did check the hose and can't find anything. Now I'm wondering if the brush itself is old (the vacuum's 15 years old) and needs to be replaced. Thanks again!
will be a good idea to do it. The vacuum will work better like a new. God bless you
