MSI RS480M-IL (816909008517) Motherboard Logo
Posted on Dec 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hdd led off
Which position can i connect the hdd led on the msi rs480 motherboard ? i have a desktop emachines t6520 .thank u
Abhinandan Patil
Level 3:
Master:
  • Master 589 Answers
  • Posted on Dec 28, 2008
Abhinandan  Patil
Master
Level 3:
Master:
Answers
589
Questions
Helped
124226
Points
1347
See to the front panel section on mother board possibly on the right hand side of bottom u can see the label there to connect hdd led
Looking for manual for rs480m motherboard
Try this one:
http://productsmanuals.com/computer-manuals/ecs-rs480-m-motherboard-manual
I need the wiring diagram that shows where on the motherboard to plug the power switch ,power LED, and HDD Led on a T6520 emachine desktop
Most Motherboards are made to only accept certain plugs in that specific spot! If you are trying to add something new like a new Fan or LED, or HHD and you need power you would have to use a 4 prong plug off the power supply, If your power supply does not have any more available plugs, Amazon.com or Newegg.com sells splitters!
Good Luck and Best Wishes!
I am trying to find the power switch diagram for an emachine t6520 thanks
On a Asus motherboard its not designed for eMachines systems because they come with a proprietary setting on the case. So what you need to is take the emachines motherboard that you took out and take the new motherboard that you bought and match the two. If there is a difference then you need to return it or buy a new case and you shift all the hardware from the emachines to the new case. If not buy a similar replacement board from emachines or ebay and you can find one and buy it. The Power setting is on all motherboards but some are different then others.
2helpful
Need to re-attach power button cable, hard drive
The manual for your computer is available from emachines, p.168 shows the info you need (replacing the front I/O panel)
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
The good news is that you can't harm the computer by connecting the wires wrong and the bad news is they just won't work the way they are supposed too if not connected properly. The LED's must have the correct polarity to work.
In general, if you look real close (as in magnifying glass and flash light) you will see the ID for each set of pins is printed on the motherboard (pwr,rst,HDD,pwr sw,speaker) Just match what it says on the motherboard to what it says on the wires. Don't worry if you get the polarity wrong. If a light doesn't work just swap the two wires. The colored wires should be positve (+), though. The reset (rst) and power switch (pwr sw) wires don't require polarity.
These instructions are for most computers in general, YMMV.
5helpful
T6410 EMACHINE TRYING TO CONNECT START BUTTON
The motherboard in your computer is an MSI MS-7145, which is also called RS480M. You can download a copy of the manual here. The front panel connections are on page 2-20.
Looking at the header JFP1, pins 1 through 9 (odd numbers) are the front row, pins 2 through 10 are the back. Pin 10 is the missing pin. The power switch connects to pins 6 and 8. The power LED connects to pins 2 and 4. The HDD LED connects to pins 1 and 3. The reset button, if used, connects to pins 5 and 7.
2helpful
2answers
I need to know the sequence on how to connect my Power LED, Reset Switch, HDD LED, and M/B Switch up correctly. I have an MS-7142 VER:1 Can you help me?
Hi carlmtclem, your not alone when it comes to hooking up the right led connector to the MSI MB. Firstly, you need to know what wire color is positive & which is negative. Most commonly the color white is ground/negative. Wire colors do vary from case to case. So look at your case led wires. Which ever color is common for each 2-pin connector, is negative. (Except the speaker wire).
All other colors are positive.
(The speaker wire color for negative is usually black & red is positive).
Your MSI board has two separate sets of pins.
JFP2 is used for the speaker only. Do not connect the power led there.
Pin one for JFP1 is shown in the manual. Pin 1 is positive & pin 3 is negitive for the HDD-LED, ECT.
Thats it.
Need more information?
Post here.
Good luck carlmtclem!
Thank you for using fixya.
Mike
Wires unpluged
these normally go at the front of the motherboard if you are looking at it where the power supply box cables are at the back. There are litlte pins that these fit onto that will say on the motherboard Hdd led etc... in small writing.
hope this helps
1helpful
I have an emachines t6520 and the power sw wire, HDD led wire, and the power led wire hve been disconected
On the system board, on the left edge next to the primary IDE connector, there is a 9 pin header.
I usually get a magnify glass and look down on the header . From right to left,you will see PWR led pins closer to the edge of the motherboard.and the Power BTN next to it.(the side of the pins that has 4 pins on it)
Then on the other side, you will see the pins for the HDLED across from the PWR led. Then the Reset pins across the PWR BTN.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
