In some cases, Windows Media Player will require an appropriate codec to properly play video (and even music files). Here you would need mov codec for Window Media Player.
You can add MOV codec and update others exclusively for Windows Media Player:
* Launch WMP and click "Help"-> "About Windows Media Player"-> "Technical Support Information"-> "Video Codecs"to view all the codecs and file formats supported by the respective codec. Or you can try Leawo Blu-ray Player whichcan support most formats including MOV.
SOURCE: Windows movie maker wont let me import videos
Open your files with Virtual Dub and save as another file name. VD is free.
SOURCE: How do I rotate a m2ts video file? windows movie
Get youself Adobe Premiere Elements and you'll be able to do much more than that.
SOURCE: the .mov 720p videos made by the Canon sx20si can't be watched
If the files are not big, you can try http://www.zamzar.com/ and convert them to .Avi for playback over the net. Otherwise, try the Rad Videos Tools (Free of Charge), but this requires a working QuickTime install, and can be found here ...
http://www.radgametools.com/bnkdown.htm
SOURCE: How can i change the MOV mode to WMV mode for
Go to "Filehippo.com" a free software site check through video programmes, you should see a file converter in there. Failing that some of the later Nero DVD writing programmes had a file conversion element. If you've got something like that check all the options.
