M4V Converter Plus is a powerful M4V DRM Removal tool. It converts M4V videos to MOV format in high speed with great quality. It is designed to convert DRM M4V video you purchased to QuickTime MOV, iPod, iPhone format. Moreover it can also convert almost all video formats could be played on your iTunes to other common video formats like MOV, MP4 or unprotected M4V.
Follow the steps, you can convert your DRM M4V movies to iPod supporting M4V fomat easily.
Step 1: Load M4V movies you want to convert.
Click "Add Movies" button, search your DRM M4V files according name, then select the files, click "Add" button.
Step 2: Select output format and output folder.
In the output droplist, select "For iPod (*.m4v)" in profile droplist.
Tip: If you choose "For iPod (*.m4v)", the output video is for iPod, and the video maximum size is 640*480.
Step 3: Start Converting.
You can press "Convert" button or click the menu Control->Start Converting to start the converting, and now the converting process begins.
Step 4: Check Output video files' Quality
After the converting process finished, you can select one of these video files, and then play it to view video effects whether it is satisfied. If you are not satisfied, you can re-customize the output setting to convert the video to other format to meet your need.
Step 5: Find the converted files quickly
After you open the converting box, you can see the default output path is/Users/username/Documents/M4VConverter Plus, but you can click the button Browse to customize the output location as you like. And Click the Open button to view the output folder quickly.
If you check the "Open folder when conversion completed", after all the files converted, it will open the output path.
You can find more info at
M4V to iPod convert M4V to iPod with M4V Converter Plus
