When accessing connection details, acts like it is connected by modem. Not the case. Have ethernet jack plugged in but doesnt acknowledge it. All files regarding router connection are gone. Lost when "vista" crashed. They are on a hidden drive. Can see them but cant access them. Do I just need to find the driver for the ethernet on dell's site and download to a disk to load (have installed xp as os) or do I need somthing more?
Patricia,
Left-click on Start, then Right-click on My Computer.
Left-click on Properties at the bottom of the list.
Left-click on the Hardware tab.
Left-click on Device Manager.
Once Device Manager has fully loaded left-click on the + sign, next to Network adapters.
What Ethernet chipset are you using? Intel, or Conexant?
http://www.dell.com/support/drivers/us/en/19/Product/dimension-1100
Communications (6)
A) Intel - Driver 9 /5/ 2006
B) Conexant - Driver 10/ 21/ 2005
Network (3)
A) Intel - Driver 12 / 1 / 2005
If you have an Intel chipset suggest you download AND install both Intel driver files listed above.
Burn to a CD disk. Put it in your optical drive of the needed computer. Go to My Computer, and DOUBLE-click on the drive letter, of the optical drive with the CD in it.
DOUBLE-click RIGHT ON the file name.
Follow the instructions of the Installation Wizard.
(Just click on Next, Next, and Finish)
Driver: Small piece of software that allows the Operating System to communicate with a device.
Windows XP is the O/S, the ethernet chipset is the device.
When asked to restart the computer - No.
Turn the computer completely off, then after 1 minute turn it on.
(Hard Start)
Still no?
Ethernet adapter card is shot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3350631&CatId=200
For additional questions please post in a Comment.
Regards,
joecoolvette
SOURCE: Windows Xp
In addition to installing the operating system (Windows XP) you will need to install the drivers for the system. If you system is a Dell Dimension 1100 you can get the drivers from this link:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_CEL_1100&os=WW1&osl=en&catid=&impid=
Driver installation order is:
Desktop system software (R121089.exe)
Intel Chipset Utility (R96614.exe)
Intel Video Driver (R104515.exe)
Audio Driver (R105155.exe)
Network Driver (R105786.exe)
Modem Driver (R133743.exe or R73044.exe)
Once you have all the drivers installed, then you can install your applications and configure your internet connection.
SOURCE: Cant connect to the internet
sounds like you reinstalled your windows, but didn't install drivers? Here you can download network and other missing drivers for your dell model http://support.euro.dell.com/support/downloads
SOURCE: Ethernet driver
ftp://ftp.us.dell.com/network/R105478.EXE This is the link for the network interface card. Once you have this installed you'll be able to go online. Go to the Dell support website and download the rest of the drivers then.
SOURCE: dell dimension 4600 ethernet port/driver issue
The link for the drivers is ftp://ftp.us.dell.com/network/R67150.EXE
If runningit directly does not install the driver go to Device manager and right click on the ethernet adapter and update the drivers. Use the manual method and browse to c:\dell\drivers\R67150 for the driver location. also the latest .netframweork is downloadable from here.
SOURCE: Old 80g hard drive crashed. Installed new 320 g
You will have to install the correct "Driver" for your Ethernet (Network) card. go to the link below and download what you need.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_PNT_P4_4700C&os=WW1&osl=en&catid=&impid=
