I know the sound works on the tv i just cant get it to come through the speakers with the dvi to hdmi cord.
SOURCE: TV is connected to a DVR with HDMI/DVI cable and
Try another HDMI scource to see what happens there. If the second HDMI works with no issues then it is just a compatability issue with the DVR to your TV. At that point you will have to use the component inputs which will offer high definition as well.
SOURCE: I have the Sony XBR 40in Trinitron and it won't
sounds like you have some cold solder or bad joints,power section, inspect it ,with the back off, but be carefull.........i had one that did that...bad connection in solder joint...had to resolder,if you have to resolder,make sure it is unpluged.hope this helped....
