eMachines E620-5885 Notebook Logo
Anonymous Posted on Sep 26, 2012
How much ram can i install in e620-5885 - eMachines E620-5885 Notebook
Anonymous
Level 3:
  • Master 2,878 Answers
  • Posted on Sep 27, 2012
Anonymous
Master
Level 3:
Answers
2878
Questions
0
Helped
487596
Points
8243
XP, Vista, and Win 7 32bit OS's are limited to 4GB, regardless of any hardware limitations.
  • Anonymous Sep 27, 2012
    Great thanks for responding!!!
1helpful
How to install ram in my Sony Vio PCG-5B1M Laptop
The RAM module/s is located on the bottom of the laptop behind a small panel. Remove this panel will uncover the RAM slots.
To install more RAM try to use RAM from the same manufacturer and RAM speed.
I have problems with the ram in my laptop what can i do? how can i find out if its a hardware problem or software
To check if you have a RAM problem, go into the BIOS and check the amount of RAM installed, does this match the total amount of RAM installed, if the RAM in the BIOS does not match the total amount of RAM in the RAM modules then you may a faulty RAM module or an incompatible RAM module.
If it is a software problem, a program may require more RAM than is installed on your computer. The software instructions will recommend the amount of RAM your computer should be installed with.
RK549AA-ABA SR2170NX problem: i think my second slot for ram is no good. i'm supposed to be able to install 2 gb max . I bought 1gb ram to install in slot # 2 but it doesn't work. can i install...
Is the 1Gb RAM you purchase the same make and speed as the original? If not, they may not be compatible with each other or the new RAM module may be faulty.
Try removing the RAM from slot 1 and insert the new 1Gb RAM module in slot and boot up your laptop to test the new 1GB RAM module.
Installing a single 2Gb RAM module should work.
4answers
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Installed ram in pc not working
Have u installed compatible RAM i.e. of same frequency as earlier RAM or just installed another RAM. Pl check for this . Also increase paging and ur system speed will do increase. Also keep ur primary partition less loaded for this.
System won'n boot if i installed two RAMs
Is the old ram working if installed alone? If yes then maybe got error or grounded if both ram inserted. Try to blow air the ram slot in the board to eliminate dirt and then try to interchange the position of the ram and then try it again.
Hope this will work.
melnavz
Trying to upgrade RAM - won't boot after new RAM installed
Install the RAM on memory slot and Switch on your system and go to BIOS settings. There you can check whether your RAM is working properly or not. If it shows no memory installed then the RAM Chip may be damaged.
3answers
Windows won't see all of my 4GB of RAM but BIOS does! Why?
Windows xp will usually only see 3.5 gbs of ram even in your motherboard can support more. WIndowns vista does recognize more RAM or i also believe windows xp 64bit recognizes more ram. Nothing wrong with ram or your computer its just your operating system.
Gateway E4100 Mid Tower RAM install
no need to install RAM in pairs.
you can buy and install memory but it should be the same model that you have now e.g. DDRII RAM Modules.
you can max out the RAM 4 gigs
2answers
Bios
try to come back with old configuration second time check new ram , may be something no good
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
