Electrolux vitesse all surface 1800w vaccum cleaner. Every time I use the cleaner i clean out this filter, but it could do with a wash if that is possible.
Thank you.
Tracey
This is a common question asked of almost every vacuum tech. In most cases yes it can be washed. For best results if it is fibre or paper, dont wash it get a can of compressed air like you would use for a computer and blow it out. if it is any other material just drop it in the dish washer on delicate cycle and be sure to let it dry for a couple days before reinstalling it.
Ps hope this is helpfull, and dont forget to rate the solution. Thanks
Should not be that loud. Check all the filters and see if they are ok. Check to see what the suction level is. This is kind of subjective. IT might have a bad bearing in the motor.
