I am having the same problem with my 2002 X5. There is a motor or fan running behind the AC control panel on the dash and if I pull fuse 48 it stops and the battery doesn't drain. Still looking for the cause and solution so that I don't have to keep pulling and installin fuse 48. BMW garage suggested that it was the Final Stage Blower Resistor. I replaced this and no change. I hope someone has an answer that will help us both.
may be you should
make a diagnostic and you can do it in a garage or you can do it by yourself
if you want to do it by yourself you need
some tools
and you can find some good ones here: diyobd2.fr
theres an anti-theft system. take positive terminal off battery, have someone holding the key on like trying to start it, then put the terminal back on and that should start it right up (had same problem in my dodge ram) if not, check all you're connections
under the spare tire in the trunk, 13mm and 15mm sockets required
