SOURCE: How do you get the precision drill bit into the
You may have to change mandrel to a smaller one. There should be 2,if not 3, in your kit. I ended up buying the 4486 keyless chuck to save time on tool changes.
I hope this helps. M
SOURCE: Dremel 395 in the middle of drilling sea glass and
sounds like the rubber connector between the motor and collet.i use rubber tubing and hot glue to keep it working. bad news is you have to disassemble it to install a new connector.
SOURCE: I inherited a Dremel Pro from my son who passed away...
you should have a little wrench that came with it
and on the neck of the dremel there is a shaft stop button
push the button and manually rotate the dremel head till
it clicks then hold the button and use the wrench to loosen the bit
Power off the PDT 3100 by pressing the "I/O" button.
Press and hold the "UpArrow," "4" and "Enter" buttons.
Press and release the "I/O" button.
Release the "UpArrow," "4" and "Enter" buttons. The scanner will restart.
Power off the PDT 3100 by pressing the "PWR" button.
Press and hold the "UpArrow," "Func" and "Space" buttons.
Press and release the "PWR" button.
Release the "UpArrow," "Func" and "Space" buttons. The scanner will restart.
Press and hold the "A," "B" and "D" buttons.
Release the "A," "B" and "D" buttons. The scanner will restart.
