Toymax Magnavox 37MF331D 37 in. LCD TV Logo
Posted on Sep 25, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Magnavox tv won't turn on or off
Buddy Mcsparrin
Level 3:
  • Master 1,684 Answers
  • Posted on Oct 01, 2012
Buddy Mcsparrin
Master
Level 3:
Answers
1684
Questions
Helped
1011150
Points
4641
The typical cause of power up problems in a failure of the power supply filter capacitors. The board can be repaired by replacing the bad components. Below is a picture of the power supply board with the bad capacitors circled and below that is a link to a it that is available with the correct parts to rebuild that board.
http://www.ccl-la.com/catalog/product_info.php?products_id=216
I hope this helps you out,
BuddyMc
1 Related Answer
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jun 23, 2011
SOURCE: We have a Magnavox 37MF231D
Please read my guides:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
1helpful
Looking for the codes for a 32'' magnavox led tv
they will be listed in the instruction or owner manual for the set or the remote being used.
Hi we have a 720 Magnavox flat screen tv that is about 5 years old. When i went to turn it on the other day the picture started flasing and making a chirp noise.. and won't fully
power supply problems does it have a separete power supply if so you can try to change or if you have someone with the same you can ask to try it.if its internal power supply it needs to be fixed.
Won't turn on
Look for loose contacts in power outlet.
3helpful
2answers
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
My 1996 Magnavox 25" TV won't work
It sounds that the tuner to your TV is faulty. A detail check is necessary to confirm. Seek expert tech support.
1helpful
My magnavox hdtv won't turn on no green or red light on the power butten no power at all
Start with the obvious. Is your TV plugged in? If it is on a power strip, does the strip need reset? If all is normal there, then unplug the set and take the back off. Check your fuse to see if it is blown.
1helpful
Magnavox lcd tv squealing won't turn on
this is a easy fix. some small pieces of lead into the front of the screen will take care of the problem . in other words go in the closet and get the darn shootgun and blow the hell out of it!!!!!!!!!!!
Top Toymax Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
