Fisher Price Geotrax Remote Control Train  Demolition Team Logo
j. elrod Posted on Sep 25, 2012
How to fix geotrax remote - Fisher Price Geotrax Remote Control Train Demolition Team
The 3 lights on my remote aren't working what can I do to fix this?
get another remote or buy another unit; but at 50 bucks for the thing ain't worth spending money to fix it.
Train lights up but doesnt move
Tried smacking the train on the concrete, didn't work. Then I smacked one side, then the other, the wheels started turning like a charm. Getting the train set up for my 3 year old grandsons visit. One happy grandma right now.
7helpful
Geotrax remotes work..trains wont go. I have cleaned contacts..new batteries...and cleaned axles
Aha! I found this on another forum and it worked for me!
I had some luck using a trick I read on the yahoo geotrax group.
Make sure you have good batteries and hold the controller in the forward movement position. Then run the train forward repeatedly on a surface with friction (I used my pant leg). I got two old trains to work again, and I'm hoping to fix one more.
The theory is that this works because it uses a magnetic coupling instead of a direct drive.
It only took me one super gentle swipe across my leg! Better than smacking/bashing them because that can knock wires loose and stuff. Hope this helps everyone! :D
1helpful
The controller for my geotrax train is not working...any tips?
Yes! Thank you! Holding the remote in forward and running the train over and over worked! It took me a few tries, and finally I did it for about 30-40 seconds continuously, and it worked!!!! Thank you!!!
12helpful
My geotrax engine will light up and the remote makes the sound but it wont move foward can it be reset?
I had the same problem with two of our three engines. I read somewhere that you can get them running by hitting the side of the engine against a hard surface. I can't believe it... IT WORKED! I guess the motor gets stuck and hitting it will get it going. All three engines are working now.
2helpful
Geotrax is not working...new batteries in remote control...batteries go anywhere else?
I assume you have batteries in the engine. If the engine light comes on and the remote makes noise, the engine motor may be stuck. Try hitting the side of the engine against a hard surface, which may get the motor moving. I had this problem with 2 engines and fixed both of them.
Nov 07, 2010 • Toys
40helpful
5answers
GEOTRAX REMOTES ARE NOTE COMMUNICATING WITH TRAIN ENGINES. SET HAS BEEN IN STORAGE FOR A YEAR. WE SET UP AND CHANGED ALL BATTERIES, HOWEVER, REMOTE DOES NOT MAKE THE ENGINES MOVE. REMOTE DOCKING STATION...
1helpful
The engines of my sons geotrax will not respond to the remotes and they all have fresh batteries
Top Fisher Price Toys Experts
ADMIN Andrew
ADMIN Andrew
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
