Is there some incompatibility issue in these combination? Foxconn G41MXE - Intel Core 2 Duo E6550
Http://www.newegg.com/Product/Product.aspx?Item=N82E16813186187
Motherboard supports Processors with a Front Side Bus (FSB) of either 800Megahertz, or 1066MHz.
1333MHz FSB support is done with OVERCLOCKING.
http://ark.intel.com/products/30783/Intel-Core2-Duo-Processor-E6550-%284M-Cache-2_33-GHz-1333-MHz-FSB%29
Intel Core2 Duo E6550 processor has a 1333MHz FSB.
http://www.manualowl.com/m/Foxconn/G41MXE/Manual/297328
I reduced the view size to 120 percent. Go to Page 27.
Press DELete key to enter BIOS Setup.
Use Down Arrow key to highlight - Fox Central Control Unit
Press the Enter key
CPU Frequency Setting should be set to 333 (333MHz)
Intel processors are 'Quad Pumped'
333MHz x 4 = Approximately 1333MHz. (1332)
http://www.foxconnsupport.com/cpusupportlist.aspx?type=mb&socket=Socket%20775&model=G41MXE&cputype=Intel
Note the version of the BIOS program also.
Regards,
joecoolvette
Testimonial: "I decided to simplify mi problem selling mi board... Thank you joecoolvette"
Think this can damage the motherboard or processor?
Have you ever tried or know anyone who has?
Perhaps you should trade out the E6550 for a Core2 Duo that has 1066MHz for a Front Side Bus (FSB), and leave overclocking to someone else.
Why? Is that bad overclocking in this situation?
No, but IMHO it is beyond what you should try undertaking. Is there anyone you can contact that has overclocked before?
Umm, I'm not a novice in the field of computers, but it's true that I've never done overclock ... Thanks for everything, we'll see what I do ...
You're welcome, and thank you for the rating!
SOURCE: how to overclock foxconn g41mxe motherboard with
I doubt very much you will get much response to overclocking here incase you do damage try www.overclockers.com
Both are LGA 775. Should work
