Whenever i want to write any image by using power iso 5.0 version on my pendrive, which i want to make bootable pendrive .... the writing method of image to the pendrive should be the HDD but after entering the path of iso or pointing the iso file ... then click on ok the writing method chaged to the "Write RAW image to the pendrive"... This cause pendrive not working as bootable even not able to open.. So i had only one option that is format the pendrive... Before few weeks ago i am using all of it with no problem but still its not working.... I have been try the change of software with new setup downloading, I had changed the Windows too.. But nothing is working...
Bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB. 2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator. 3. When the Command Prompt opens, enter the following command: 4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do. 5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter. 6. Go back to command prompt and execute the following commands: 7. Copy Windows DVD contents to USB. http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/ boot from a usb drive
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.
CD BOOT and hit enter to see the below message.
BOOTSECT.EXE/NT60 H:
(Where "H" is your USB drive letter)
You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
hope this helps
SOURCE: bsod, error code:0x00000024, hdd problem booting xp os
Can you do this
Boot from the Windows XP CD.
Watch for a Press any key to boot from CD... message similar to the one shown above.
Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, simply reboot and try to boot to the Windows XP CD again.
When the Windows XP Professional/Home Setup screen appears, press R to enter Recovery Console
Select your OS and enter password (if needed)
When you reach the command prompt type the following and then press Enter:
expand d:\i386\hal.dl_ c:\windows\system32\hal.dll
Using the expand command as shown above, d represents the drive letter assigned to the optical drive that your Windows XP CD is currently in. While this is most often d, your system could assign a different letter. Also, c:\windows represents the drive and folder that Windows XP is currently installed on. Again, this is most often the case but your system could be different.
If you're prompted to overwrite the file, press Y.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
SOURCE: sony vaio vgn s460 - severely virus infected.
Hi
It is in safe mode that you need to run your anti virus scan and hopefully this will erase all the viruses on your system
I hope this helps
SOURCE: Ok.. I am no tech expert so I may need some help
To get safe mode and depending on the machine you need to press and hold f6 or f8 just after the intial boot screen shows. This will allow you to get to safe mode selection on your pc.
SOURCE: I have a Sony Vaio
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Hi.
You may download the latest version of the VAIO Update Software from below link:
http://s02.download.sony.com/US/pc/SOAVUD-00225916-0042.EXE
Once you install the latest version of the Software, please restart the Computer for the settings to take effect.
Installing the latest version of the VAIO Update Software should resolve the issue.
Hope this helps.
Please feel free to contact for further assistance.
Thank you.
Suresh
