I have charged my rechargeable battery then i have placed my battery inside my camera but after inserting the battery symbol is blinking red and after few minutes it is showing to charge the battery.i have changed the battery but there is still the same problem goes on what should i do?
SOURCE: Canon Powershot A540 - Change Batteries when Batteries Fully Charged
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
SOURCE: Battery Fully Charged Camera Won't turn on
Hi
There are several things that could cause this.
1-
Check the battery door indicator switch under the battery door and
beside the memory card slot. Is the little black switch damaged or
missing? Try pressing down gently using a pen it with the door open and
then press the power button. Does it turn on?
2- The fuse has
blown and needs to be replaced. Offhand I don't recall where it is on
the SD600 PCB or how hard it is to solder on a new one (depends on if
its tricky to get at or not). Good thing is fuses are really cheap.
3-
Other power problem with the PCB due to corrosion or impact damage. The
PCB or 'motherboard' of the camera will need to be replaced.
A couple solutions would be to either buy a defective camera online and
make one good camera from the two if you can do that sort of thing
yourself, or secondly have it repaired by somebody.
Don't bother
trying to send the camera to Canon if it is out or warranty (though you can call them and verify
what I'm about to say) because they will want $150+ to do the repair
for you. Parts are not cheap to buy from them.
I know of
one very affordable digital camera repair business... because I own it.
The name is Darntoothysam, feel free to check us out, we are on that
big auction website also (I don't plug their name for free), our seller
ID is 'darntoothysam'. If you Google "darntoothysam" you will find us.
If we can help with your repair then please let us know.
Hope this helps,
Thomas
SOURCE: Canon Powershot A470 - asks to 'change battery'
This happened with my Canon Powershot A470. I sent it back to he manufacturer and they said I was using the wrong batteries. Even though the camera is supplied with two alkaline batteries, they recommend using AA NimH rechargable batteries.
SOURCE: canon sd1000 camera won't turn on. battery is fully charged.
Make sure or Check out following thing :-
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
SOURCE: no power - fully charged battery
How about cleaning the battery contacts in the camera first with a pencil eraser and then, with a cotton swab lightly dampened with rubbing alcohol.
