My kids locked my rca dvd player model rc5220p
How can i unlock or reset this dvd player
  • 15,935 Answers
The Disc Tray is Locked
If the message “Tray Locked” appears on the screen, the retail lock feature has
been accidentally engaged. To unlock the disc tray you must press and hold a
combination of keys simultaneously:
On the front panel of the DVD Player, press and hold the STOP, ON•OFF and
OPEN•CLOSE buttons for at least 3 seconds.
I forget the password Your player is equipped with a “back-door” unlock sequence. Press and hold
the STOP button on the front of the DVD Player and the STOP button on the
remote control at the same time. (Hold both buttons down at the same time
for at least 3 seconds).
Posted on Dec 28, 2008
  • Deidre Jago Dec 05, 2011
    wow..thank you,it worked.i will be adding this very helpfull sight to my favourites bar.
    Genius:
  • 1,011 Answers
Click this link
SOURCE:
Have rcu310bb remote. Need how to use with rc5220p dvd player
Hi
RCA codes to check with RCA RC5220P are:
3150, 3356, 3363, 3372, 3412, 3423, 3424, 3426, 3443, 3470, 3480, HTIB: 3444, Portable: 3163
1* Manually turn on the component
you want the remote to control.
2* Locate the enclosed Code Lists.
Find the list for the component you
wish to program. Find your
component's brand. You will see a
listing of four-digit codes for each
brand. If your brand isn't listed, use
one of the Code Search methods to
program the remote control. (Refer
to pages 7 and 9 for Manual and
Auto Code Search methods.)
3* Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you
wishto program. The illuminated
ON•OFF key turns on and
remains on. If you release the
component key at any time
during the Direct Code Entry
procedure, the illuminated
ON•OFF key blinks four times,
and the process is exited.
4* While holding down the
component key, consult the Code
Lists for the four-digit code that
corresponds to your component's
brand and use the number keys
(0-9) on the keypad to enter it.
While you are pressing the
numbers, the illuminated
ON•OFF key turns off.
5* After the fourth number is
entered, the illuminated ON•OFF
key turns on. At this time, release
the component key. If the
illuminated ON•OFF key turns
off, you have entered a valid code
and have followed the correct
procedure for Direct Code Entry.
If you enter a code number that is not
in the Code Lists or you do not follow
all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks
four times when the component key
is released. This is an indication that
a programming error has occurred.
In that case, repeat the Direct Code
Entry process from step 3.
OK.
Jul 10, 2011 | RCA RC5220P DVD Player
Code not turning off dvdplayer using dish network remote
This often happens when the remote is programmed to a code that's close but not the right one to control that specific model of DVD player. If the remote was powering off the DVD player before it may be a bad remote. Try this link you can try reprogramming the remote. Hope this helps!!
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Daniel Busa
DISH Network Customer Service
Dec 26, 2010 | RCA RC5220P DVD Player
Need a user manual for DRC6300N . Ours says"locked" and dont know how to unlock it
Try this page... they say they don't have the particular manual but it may help to unlock
http://www.retrevo.com/samples/RCA-manuals.html
Lock/Unlock DVD player
• To lock player, open tray and press SETUP, 0, 0, 0, 8, 3 (an on-screen message, "Key
Lock On" is displayed).
• To unlock, press SETUP, 0, 0, 0, 8, 3.
This from another RCA manual but may work
Cheers
mickypics71
Sep 17, 2010 | RCA DRC6355N DVD Player/VCR
Only playing in black and white
There is a regular video out jack in the rear of the DVD player
Try that to the Video -In on the TV
Also. with the component video , make sure the colors all match at both ends
Apr 18, 2010 | RCA RC5220P DVD Player
My niece set the lock code and forgot it. How do I unlock it so i can watch my regular rated R movies
On your remote enter 73856525000100X (replace the X with your region code then press info key. These instructions come from www.dvddemystifiziert.de/codefree or you can google on "unlock rca dvd players and you'll see the site to click on that shows all the different models and instructions for each one and the ones that cannot be unlock.
Nov 17, 2008 | RCA RC5220P DVD Player
Parental password control inadvertently activated.
Called Zenith. They said: turn on the DVD player. Hit "set-up". Scroll down to the "lock" icon. Scroll over to "Rating". Scroll over to unlock. Enter 0000. Click on Ok. Enter 0000 again, click Ok again. Menu should read unlock. Voila!
Nov 11, 2008 | RCA Televison & Video
Get error message: disc not compatable or no disc
have you bought the new disc's from stores cause cd's and dvd's come in new format which is forcing people to buy new players if old dvd's worked on dvd player and new ones dont then its the dvd i had to by new dvd player the other night cause im startin my collection dvd's back bought a movie and bam didnt work no disc
you can hook the line direct into a vcr audio and video and it works with out the R.f's adapter
May 07, 2008 | RCA RC5220P DVD Player
Unlock code for Toshiba SD-270EKB
dvd model SD-270EKB
1.power on dvd
2.open disk tray
3.while tray is open press 98790
the last number zero represents all regions unlocked.
Apr 06, 2008 | Televison & Video
RCA DVD PLAYER RC5220P
Nov 28, 2007 | RCA RC5220P DVD Player
NOT PLAYING DVD'S
Have you tried that dvd in another player?
Have you tried another dvd in your player?
Since this began after you moved it, do some backtracking.
If someone says...it quit AFTER I did...such and such, then THAT is most likely the cause.
I have solved many problems by backtracking.
Oct 16, 2007 | RCA RC5220P DVD Player
Televison & Video Logo
870 people viewed this question
Top Televison & Video Experts
Ekse
