SOURCE: I have the frigidare affinity
You need to replace the door lock mechansim. Fairly easy to do yourself, just pull the spring strap off the rubber door gasket and remove 2 screws holding door lock. Install new door lock and re-install door gasket and spring strap, and WALLA! she works:)
SOURCE: Frigidaire Affinity Washer beeps & won't spin
The drain filter is clogged. I had the same problem. There is a filter inside the "drain boot" (black) that comes from the drum to the drain pump. Mine was completely clogged with money, lint, etc..
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
Hello gen0313 - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. A certified technician will need to accurately diagnosis the bearing and pulling system behind the drum for repairs.
FRIGIDARE WASHER WONT BEEP ANYMORE WHEN COVER IS LEFT OPEN
