Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven Logo
Posted on Sep 25, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why has both top elements stop working at the same time
  • Official Brand Answer 4,342 Answers
  • Posted on Sep 25, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1467775
Points
5907
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Oster 6-slice counter top oven model TSSTTVMNDG
Check the element with a Digital Multimeter set for continuity (Ohms). If no continuity, the element has failed.
https://www.google.com/search?q=oster+tssttvmndg+element+replacement
Nov 04, 2023 • Ovens
Frigidaire FEF366CCB classic series electric oven. While I was away the oven stopped working. No heating elements in the oven or stove top at all work. The EOC still shows time, no fault code. Ideas?
check breaker or power feed my not be getting correct power to the unit may only be getting 110v which electronic circuits work on instead of the 22ov that the elements and coils work on
3helpful
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
The oven won't work, neither elements, both stopped working at once. Stove top elements still work normal, as well as all other functions, just no oven. Tried to find fuses and could not locate any. Can...
It sounds like an electronic clock/timer problem. The clock must be in the manual mode for the oven to work. It sounds like it might be in auto. mode for both elements to stop working at the same time.
How about if the top and bottom elements (bake & broil) both do not work and seem to have quit at the same time. Same as prior the stove top elements all work fine.
It is a bit suspicious if both stopped working at the same time. It has to be a common fault. The first thing I would check is the wiring at both elements. You will have to pull the back of the range off to check this. If okay I would suspect the controller which controls both these elements is faulty. Another solution maybe the oven thermal overload but it isn't that common.
2answers
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
1helpful
The oven stopped working and heating up. The top range part works.
I suspect a heating element in the oven has burned out. Some ovens have 2 heating elements, one on the bottom for baking and one on the top for broiling. If this is the case, you can try setting the oven on broil and see if the top element gets hot. Usually the bottom element fails first because food gets dripped on it. In most cases you can unplug the old heating element by just pulling on it and plug the new one just as easily. You can check the resistance of the heating element with an ohm meter. If it's burned out the resistance will be very high, probably greater than a mega ohm. In some cases you will need to take the back off the oven to replace the heating element. Just make sure the oven is unplugged and cool when you start working on it.
May 11, 2009 • GE Ovens
Broilers suddenly stopped working
gerrie824 look at the elements and see if there is cracks in them. If so then yes they failed. During bake the broil elements come on in 1/2 power to brown the top of what you are baking. If there isn't a break in the elements, then the issue could be a burnt wire, failed relay, or such.
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
