Question about JBL PB12 Subwoofer
Subs hum when i turn of my stereo - JBL PB12 Subwoofer
  • 5,807 Answers
When it only hums when you turn On the stereo, check the cable and connections .
When it hums, even without anything connected to it, then it needs repair
Posted on Oct 23, 2012
SOURCE:
Why is there low humming in the receiver sub channel(only?)
Sounds like a shorted capacitor in the sub out circuit.
May 04, 2015 | RCA Audio Players & Recorders
My sub randomly started making a loud humming noise. The stereo was not even on at the time.
The humming sound is 60 cycles or a harmonic thereof emanating from poor filtering in the power supply. Better get the supply serviced before the speaker gets damaged.
Mar 21, 2015 | Audio Players & Recorders
Bose av18
Hum is tough. It is often caused by quite a variety of things. First, address the basics:
1. Make sure that none of your signal cables run near to power cabels.
2. If possible, feed all power from the same receptacle.
3. If your plugs are not polarized, try reversing one at a time.
If none of those basic checks uncovers your demon, verify the path of the noise by disconnecting the signal from the preamp at the input to the sub. If is still hums, then look closely at the power feed to the sub, More likely, the hum will stop (along with the music.) In this case, try breaking the shield ground at the sub input (e.g. with a ground isolation adapter.)
You should also confirm that the hum is limited to the sub. Subs tend to exaggerate hum because playing signals in the 60Hz is their forte. So with the sub turned off and bypassed, listen for the hum in your main speakers. If it is there, too, then start checking your sources. Remember, even a source device other than the one selected for play could be the source ... completely disconnect each source at the preamp to track it down.
Aug 03, 2014 | Bose Audio Players & Recorders
The subwoofer output on my Kenwood VR-606 has suddenly stopped working. I have tried the "setup" several times, turning the subwoofer off and back on. Also, when I first power up the system, it emits a low...
It sounds like the problem is not with your VR-606. If you hear a hum from the sub, the problem is more likely to be in the sub's built-in power amplifier. However, it is worth resetting the amplifier to factory presets. To do this, unplug the power cable from the mains supply and reconnect whilst holding down the power on/standby key. If the hum persists, connect any powered speaker to the sub-out socket, power on and listen for the hum. If no hum then suspect the powered sub amp. Turn the sub on with no connection to the Kenwood VR-606. If hum persists, the sub has a problem and will need to be replaced or repaired. By the way, you said there is a low frequency hum through the 'speakers' for about 30 mins. Is that all speakers or just the sub? Hope this helps.
Cheers, Don.
Jul 06, 2014 | Kenwood VR-606 Receiver
Esw-c10 subwoofer hums and dont work
if you short a sub it will hum try connecting it to a working speaker (no amplifier) if you have access to rear of sub check for wire only needs to be the size of a hair arcing out the speaker, i have a sub that does that on only one output (left rear) its actually the stereo causing it to hum..
Jun 20, 2012 | Energy ESWC10 Subwoofer Speaker
Sound from reciever
LFE (ONE CABLE ON THE SUB TO SUB OUT ON AVR) OR stereo L/R analog cable from sub to tape in/or out on avr (depends on AVR) LFE connection the sub turns up with the AVR - the stereo cable threw tape in/out on AVR only turns up via its own onboard amp volume from AVR has no affect.
Aug 21, 2009 | Sony STR-DH700 A/V Receiver
Battery Draining
Disconnect the stereo and watch the condition of the battery. Most of the time the stereo gets power out of the battery even when engine is off.
Rate this.
May 26, 2009 | 1993 Ford Probe
Sunfire Subwoofer 110 Noise on input plugin
A few more questions-
Does the sub hum without anything plugged into it except for power? If it makes a real loud hum almost a squeal then I think the rca cable between the receiver and the sub is dead shorted and needs to be replaced. If it's more of a low level hum, then it's a ground hum caused by many things, ie........the receiver and the sub being on different power circuits in the house.......sometimes diconnecting the cable tv feed as it enters the room while the sub is connected and humming to see if it stops........the easy fix sometimes is using a 3 to 2 prong ac adapter but lifting the ground on such a powerful amp could be a fire hazard.
Sep 25, 2008 | Sunfire True Sub MK II Subwoofer
Onkyo Subwoofer Pre Out Problem
May not necessarily be the out put, discontect the sub from the receiver and see if it still makes a hum, Making sure that you turn auto on, off on the sub woffer.
If it still makes a hum, then you have a earthing problem, you can get a earth filter put on your internal wiring in your home, or you can remove the earth pin on your sub woffer
Dec 13, 2007 | Onkyo TX-SR502 Receiver
JBL PB12 Subwoofer Logo
125 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
