I want to know how to return my hp g60 laptop to factory settings
Press the "Start" button in Windows Vista. Select "All Programs" and "Recovery Manager."
Click "Advanced Options."
Select "System Recovery." Click the "Next" button.
Click the "Restart" button when prompted by the on-screen instructions once the recovery is done.
After restarting the computer the system is back to its factory state. hope this helps
SOURCE: laptop fingerprint problem
IF YOU WANT TO RESET FACTORY SETTING, JUST USE THE ORIGINAL BACK UP OF OPERATING SYSTEM, BUT BEFOR TO DO THAT SAVE FIRTS ALL INFORTANT DATA IN EXTERNAL HDD.. TO AVOID LOSS FO INFORTANT DATA IN YOUR SYSTEM THEN,, RESTART THEN HIT THE F 11 TO RESTOR SYSTEM..
SOURCE: My Hp g60 laptop battery is not working
hai,
i think the problem in battery so try to get new battery and follow the tips to prolong u r battery life through nbbatt blog
SOURCE: advent 7113 laptop very slow would like to return
After researching all the information online, I have put up the maximum possible detailed steps to help you out:
Your Advent computer uses the latest recovery
system that doesn't require any CDs or DVDs to restore your PC to it's
original factory condition.
1) Restart your Computer.
2) Press F10 repeatedly until the message "Starting System Recovery" is displayed.
3) The recovery will load and display a menu of options:
(a) Non-destructive recovery:
this option will restore Windows, supplied applications, and drivers.
This option will not destroy your documents or programs. These will be
backed up along with the registry. These are restored at the end of the
recovery process.
To access the recovery options below that erase all data from the computer, click the Advanced button.
(b) System Recovery - No format: this will reinstall Windows®, supplied applications and drivers. It will move your files to a folder called "My old disk structure". Any applications (except those supplied) will need to be reinstalled.
(c) System Recovery - Quick format:
this option will erase your hard drive including your personal files.
Windows, supplied applications and drivers will be reinstalled.
4) Select the Non-destructive recovery option and press Next.
5) You will be informed about System Restore in Windows, click Yes.
6) The recovery will begin. Once this is complete click Restart.
Here are some additional information:
a) Press the ALT and D keys at the Windows style recovery menu options to access a command prompt. This will allow access to C: drive.
b) The command prompt will default to c:\minint\system32 where you can run a variety of tools including CHKDSK.EXE.
c) For more information on these options, please read the Advent recovery trouble-shooter.
Advent recovery trouble-shooter:
If a user is experiencing recovery problems on an Advent PC, then try to follow these steps.
Note: These steps will
remove all personal data and all applications installed after the PC was
purchased. Where possible ensure that all data and personal files
are backed up BEFORE trying these destructive diagnostic steps.
1) Check the integrity of the recovery CD, or the update CD.
2) It is possible to verify the integrity of the recovery CD, or the update CD from within the Recovery programme.
a) Boot from the recovery C.
b) At the ‘Press R to display system recovery options’, press ‘R’.
c) Once in the System Recovery screen, press ALT + D to access the WinPE command prompt.
d) Type in Xcopy D:\*.* /E /V C:\ and press Enter.
e) D:\ is the CD ROM drive letter
C:\ is the HDD
/E copies everything
/V verifies the data with a CRC check.
f) If there is an error with the CD, then you will get the message:
File creation error – Data error (cyclic redundancy check).
g) If there are no errors, then you will be left at a prompt again.
3) If Windows® is accessible, then boot from the recovery CD.
4) At the ‘Press R to display system recovery options’, press ‘R’.
5) Once in the System Recovery screen, press ALT + D to access the WinPE command prompt as below:
6) Type COPYSI and hit Enter. This will unhide the user's smartimage (this may take a few minutes to complete).
7) Return to Windows® & copy the contents of the C:\Update CD\ folder to CD (N.B. Do not copy the ‘Update CD’ folder itself). Ask the user to label this ‘UPDATE CD’.
8) Start with the recovery CD ROM in the CD drive.
9) At the ‘Press R to display system recovery options’, press CTRL + BACKSPACE to get the hidden menu as below:
10) Choose option:4 (Clear the partition table of drive 0x80). Once you have selcted this, you will be returned to the Press 'R' screen.
11) Choose option:5 (Erase the Master Boot Record of drive 0x80). Once you have selcted this, you will be returned to the Press 'R' screen.
12) Choose option:7 (Create a primary partition on drive 0x80). Do not restart the machine during this process.
Option 7 may sit for up to 10 minutes with a flashing cursor as it
creates the partition. If the HDD LED is flashing, then you know that
the process is proceeding.
13) Once the HDD partition has been created you will be returned to the ‘Press R to display system recovery options’ screen. Press ‘R’.
14) The recovery should go straight into a full destructive recovery, and will ask for the update CD which we have created.
Hope this Helps.
Please feel free to ask further questions.
SOURCE: My HP G60-120US 15.6" Widescreen
Update and refresh the drivers.
click on start icon, type"device manger" and click on image viewer on the drop down right click on it and update the drivers and see if it is working,
If not then right click and uninstall and restart the computer and try
to use if not post back.
Hope this helps.
Cheers!
SOURCE: I NEED SERVICE AND REFERENCE
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=3860153&
You find any avaible manual at this site.
If this information was helpful, Please rate it high. thanks
