My card is a Hauppauge HVR-3000 (14109 LF ver: B3D3). I have problems with WinTV radio software under Windows 7 64 bit. For TV watching I installed ProgDVB 6. It works fine (problems only with MPEG 4 codecs). I also want to use the FM radio tuner of the card, I installed the WinTV Radio software. During installation I got a message of Windows that this software is not compatible with Windows 7. Anyway I finished installation because I don't know any other program wich would work as radio for my card. I can't hear any sound however the radio station is tuned and I can see a high signal strength. I checked audio mixer in Windows but nothing is muted. The card does not have any audio out socket, so I can't find where the problem is. Any suggestions? THX in advance.
SOURCE: WinTV-HVR-1600 Tuner card to DishNetwork receiver
Yes, but what it can connect to depends on what Dish DVR you have. The newer, HD ones only have HDMI, S-Video, and that 5-split coax as outputs for the main TV since you only get these box's if you have and HDTV.
This is because regular old coaxial is no longer good enough for them. This means you must connect the newer DVR's to the S-Video input on the Hauppauge1600 since it is the only input to the card the Dish DVR supports.
If your DVR is older and has the coax out, you can use that and connect it to the Hauppauge analog input.
SOURCE: xp media center says no ntsc tuner installed
Okay, Media center does not work with some Wintv HVR's yet it will work with the software it came with and sometimes media center will use the wintv software to make it work but its sketchy. If you want a more media center compatiable card look at www.microsoft.com website they have a list of media center compatable Tv tuner cards, Trust me I am having the same problem with my tuner card now and its not wintv its a RCA and its under windows 7 this is just the thing here not all card work with media center.
Thanks for using fixya.com please do click the accept button.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: Dell? Hauppauge WinTV-HVR-1250 TV Tuner
Make sure you have the remote sensor plugged all the way into the connector on the card. Also check your taskbar for the "remote" icon which confirms you have "irblaster32.exe" installed.
