Inside this External HardDrive is I believe a Internal Laptop HardDrive. On You Tube there are videos of how to dismantle it, just type the name in You Tube and if you get leads you should be able to connect it inside a P.C. and retrieve yours important files.
If the connections are the same as an Internal P.C. HardDrive your in luck.
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismatle of your External HDD.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread....
http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues'
Well, it works now. Don't know how. It still clicks everynow and again, but the port on the HD for the USB cable was moved out of place. This is what I think caused it, but thanks anyways.
