In side your washer you have counter weights they look like breeze blocks are these tight also there should be a couple of what look like small shock absorbers have a look to see if thet are still working the only other thing i could sugest is make the loads smaller especialy with jeans and wooly jumpers as these soak up a load of water hope this helps ivan
SOURCE: washing machine
Plug off the wall. Open up behind to see if all connections a fitted securely. Especially from the control unit to the motor................
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
SOURCE: fisher and paykel washing machine becomes
i think that 1 or more suspension rods r faulty. lift the lid and at the front of the machine u will see 2 plastic covers, remove the covers and undo the screws underneath. now lift the front of the hob up gently and u will see the suspension rods. they r easliy replaced. but first see if they havent just popped out. if they have just popped out look at the other 3 and refit to how the others are.if u need more help or u find another problem reply back and i will help u more.good luck
SOURCE: Fisher & Paykel Washing Machine WL80T65CW1 Fault 9
sounds like a size error . when you changed the display did you size your machine to the new display module?did you get the re-size set of instructions with the new display board? ring up where you brought the display from and i"m sure they can help. if not reply back and i will guide you thru it.
