Error will not go away after inserting new Canon cartriges and restarting printer
SOURCE: Canon MP530 U052 Error
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
NB. I have seen some suggestions that canon's have a 'Service Mode' that allows you to disable the cartridge chip checking and allow you to print no matter what .. however I've never found any details ... perhaps some-one else has the details ??
SOURCE: Cannon MP600 error message U052
hi there,
You
the first time ...
SOURCE: On my Canon MP530 multifunction printer I have the
Sounds like a print head issue & might need servicing or replacement. Suggest you contact Canon direct for help.
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
SOURCE: Getting error code U052 (
Hi, please get new driver here:
www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay lnkv
SOURCE: my canon MP810 all-in-one printer, i've cleaned
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
If
one of the ink cartridges is missing, this error will occur. U075 /
U076 The ink cartridges are not installed in the proper position. Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
Replace the ink cartridge.
By
pressing the OK button, printing can be done without replacing the ink
cartridge. However, the remaining ink amount cannot be detected
properly, so the function to detect the remaining ink amount does not
operate. READ/WRITE MODE Since the memory card is currently
write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO
PHOTOS ON CARD Some images in the memory card may not be in a supported
format. images listed below cannot be printed directly from a memory
card. Print them from a computer.
The waste
ink absorber is a part inside the printer, which absorbs ink used in the
cleaning operations, etc. CHECK PRINTER Turn the printer off, and
remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If
the problem is not resolved, the printer may require servicing. Please
contact your local Service Center.
i did , but it wont go away
