You will have to remove all the screws on back of TV Front Bottom panel first then you will have more screws that hold Top on in back and under front screen its not as bad as it sounds it just takes awhile to do while your in their clean your mirror and all 3 top lenses to Tubes.
one thing to check is to see if your model has a speaker swith on the rear panel and see that it didnt get bumped to off
other wise check speakers in the menu to see if there turned off
if not there then you will have to trouble shoot the small signal board
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
CRT Rear-Projection - Before
you can begin cleaning, you need to determine if you do, or do not have
a screen shield. A screen shield is a hard plastic cover over the front
of the TV screen. If you can't tell, give the front of the TV a light
tap. Another way to tell is to check for ridges in the screen area. If
you can feel ridges on the screen, then you do not have a screen
shield. Rear projection TVs without a screen shield require a special
kind of cleaner and rag. These are available for purchase at your local
TV service center. Those that do have a screen shield should be cleaned
with a dry or damp soft cloth. If it's extremely dirty, a mild soap may
be used. Do not use paper products, such as paper towels, to clean the
screen shield. Paper products can easily scratch the surface of the
shield. Screen shields can have a tendency to streak while cleaning. If
this happens, use a dry cloth and buff the screen in a small circular
motions.
