Soyo DYLT032C 32 in. LCD Television Logo
Posted on Dec 28, 2008
My Soyo DYLT032 has power but no picture or sound
I have a Soyo DYLT032C 32; the power comes on but no picture or sound, just a blue screen. The buttons on the tv will not work either. I know I need a new remote but shouldn't the buttons (for changing channels and volume) on the tv work?
Thanks...
  • 2 more comments
  • HOWARDWINTER Feb 01, 2009
    I HAVE THE SAME PROBLEM-WHICH BOARD AND WHERE IN THE BACK----I SEE POWER SUPPLY BOARD ON TOP....IS IT ON LEFT SIDE OR MIDDLE?((((((((((SOYO DYLT032C)))))))))))))
  • Anonymous Feb 03, 2009
    I have the model MTSYTPT4218AB6L0084 42 ' flat screen with the same problem powers up but no sound or picture the screen goes black after a few seconds..i tried the reset button thing with no luck..anymore idea?
  • Anonymous Apr 05, 2009
    After what I thought was a fumbling at the remote, I have no sound on this TV. Two calls to customer service resulted in "you need to take it to a repair shop." Is this a sound board replacement, or an internal reset fix? The set is less than 3-years old...just out of warranty.
    I have almost the same problem, but it is just sound. The last thing I did was to fumble with the remote. After an hour of trying to resolve the issue and two calls to customer service, I was told to take it to a repair shop.
    The set is less than 3-years old and feel that there is an easy fix for it, but what?
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Jan 20, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3976
Points
19
Long story short:
Had the same problem with my Soyo.
Thought it was the power supply board problem that everyone else was reporting.
ordered one.  Plugged it in.  Did not work.
Inspected the Main/Logic board and found what looked like a black button that could be depressed.  It is located to the right of main processor on the board.  You can't really miss it.
With the TV plugged in, I pressed the suspect button.  The TV made a buzzing/clicking noise for a few moments and the stuck blue illuminated power button faded away.
Curious by this, I pressed the power button and low and behold the TV comes to life!
Looks like I found a "reset" button which seems to have fixed my problem.
Thanks Soyo for not bothering to mention that such a button exists.
I hope the rest of you have the same good luck.  In the event you are still in need of a power supply board, email me.  I have a spare now it seems.  ;)
1 Related Answer
Anonymous
  • 6 Answers
  • Posted on Jun 30, 2009
SOURCE: My Soyo DYLT032 has power but no picture or sound
I HAVE FOUND 2 2200uf CAPS ON THE POWER SUPPLY BOARD THAT ARE PUFFED UP. CHANGING THEM USUALLY SOLVES THE PROBLEM. THERE'S ALSO A RESET BUTTON ON THE MAIN BOARD YOU MAY NEED TO RESET AFTER CHANGING THE CAPS.
What does a power cord for at 32"flat screen TV look like for Soyo digital TV
This cord looks like a regular 3 pin cord used for things like computers, etc. You can get them from home center stores, hardware stores, computer stores etc.
I ahve a SOYO LCD model DYLT032c, the set will not power on and the power led does not light
1. This may be a fuse blown in the start up circuit or a rectifier diode at the AC input ( the primary side ) side of the main board.
2. In any case this will require a testing of components at the power supply of the main board by a qualified tech. A schematic is require to trace all defective components and replace them about 1 to 2 hours to isolate and repair.
I need a new power supply board but cant find one anywhere
Ur could purchase new power supply at these website.Tv Repair World.com,Shopjimmy.com, Partstore,or Ebay.com.
Blank tv but has sound
A couple of questions,
What make and model TV.
Are you using a external Digital receiver for digital cable or satellite.
Are you using a surround sound receiver.
I will have a better answer for you after you answer these questions.
SOYO DYLT032 LCD TV Power Supply
I can repair the power supply for you if you like depending on where you live repair is about 150.00 shipping may be a little extra
David
[email protected]
8helpful
3answers
Problems with Soyo DYLT032C 32 in. LCD Television. The TV will not turn on, I have un-plugged it and plugged it back in, in hopes it would re-set the tv. Do you have any suggestions?
Long story short:
Top Soyo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
