Question about Hotpoint Washing Machines
My hotpoint washer wont agitate spin or drain. it makes a clunking noise when you try to change the cycles
My washing machine fills with water but wont agitate, wash, rinse, spin or drain. it is full of water and I cant get it to empty or do anything else.
  • Hotpoint Master
  • 8,220 Answers
Might have strings or coin in the pump.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 24, 2012
SOURCE:
SOURCE: Whirlpool Model LSV6234AWO
door switch bad?
Posted on Oct 18, 2008
SOURCE: washer machine not draining water
The GE serviceman repaired my machine approximately 40 minutes. I paid $189 for the issue to be resolved in 5 minutes. This is no exaggeration.
The serviceman arrived at 2:50pm and finished at 2:55pm. It took another 5 minutes for me to write the check and he was gone.
My recommendation is...
- Purchase the GE service plan prior to calling GE to repair the service. A 1-Year service plan is $40 and 2-Year is $75. It costs $99 just for the serviceman to come to your house.
- Fix the issue yourself. Of course, this only applies if you are handy. I am handy and I tried to fix the problem myself. I just couldn't figure out the location of the access panel.
Solution...
The access panel is on the front. This can be removed in less than 20 seconds. The notches on the access panel is in line with the edging of the washing machine door. To remove, slide in a flat object like a flat-head screwdriver. Wiggle up and down on each side until door comes loose. Lift up door and set aside.
The water pump is on the lower right in the front of the washing machine. If your wash machine has any water in it, you want to use a shop vac to empty it out. The serviceman used a clamp to stop the water from running down. A little water still came out but he used my shop vac to get it up. It was less than a cup full and I had a 1/2 tub of water. Afterwards, he stuck his fingers in the water pump and pulled out the item that was blocking the pump.
Guess what was blocking the pump? The item was my two-month old daughter's sock. He recommends using a washing bag.
Remember this solution is for GE 315 model that is a top load washer. This will most likely work with similar models. I knew my water pump was still working because it hummed during the rinse and spin cycles.
Good luck and I hope this saves you $189 or any other fees.
Posted on Feb 09, 2009
SOURCE: washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Posted on Feb 21, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
  • 1122 Answers
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Posted on Apr 24, 2009
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
Whirlpool wtw5100sq0 clunks when put on spin cycle
Does the washer currently work fine aside from the loud clunking noise? Does the clunking noise continue or is it just one loud clunk when it starts to spin? If its just one loud clunk then that is not a problem just ignore it as that is the clutch spring releasing, it probably starting making noise from the grease getting washed off when the washer over filled.
However how did the washer overfill? That issue should be addressed too. Sometimes though, if the tub is not centered from a heavy load the water will spill over the back but its not really an overfill.
Mar 25, 2013 | Washing Machines
My hotpoint washer wont agitate spin or drain. it makes a clunking noise when you try to change the cycles manually
The draining problem could be something stuck in the pump. A easy fix just take it apart and get whatever is in it out of there. The agitator sits atop an agitator drive block. The spline on these tends to strip out. Yank off the agitator (it just snaps on) and replace the drive block.
SERVICE MANUAL
My page shows more HERE
Sep 24, 2012 | Hotpoint VVSR1070D Top Load Washer
Kichenaid kawe570bal0 agitator clunks
there is a gear, pop the top cap off the agitor, the gear is in there, near the top might need to be replaced, sears has most parts for most machines
Oct 03, 2009 | KitchenAid KAWS850L Top Load Washer
Agitater problems will not agitate
To Reset computer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly to reset computer. This should solve your problem.
May 09, 2009 | GE WBSR3140DW Top Load Washer
Apr 24, 2009 | Washing Machines
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Washing machine will not spin
If this is a Whirlpool washer, you have a broken motor coupler
Jan 23, 2009 | Washing Machines
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
218 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
