Is the tailgate from a 1995 Toyota 4Runner interchangeable with the tailgate from a 1997 Toyota 4Runner?
SOURCE: Toyota 4 runner spark plugs
Not a big deal. Realize that the plugs from the factory are Iridium and are good for 100K miles. Assemble the following:
6 Denso IKH20 Iridium Plugs pre-set to .044 gap ($10 each) High Temperature anti-seize (crayon type is $3 at NAPA)
3/8 inch drive ratchet
5/8 inch spark plug socket
4-inch extension
10-inch extension
10 mm socket
12 mm socket
torque wrench (or make real sure you don't over tighten the plugs) new air filter (optional)
Start on the passenger side. Disconnect the air induction/filter assembly by un-snapping the two spring latches on the black air intake box closest to the front of the car. Once these are un-latched, fold the air intake assembly out of the way. Now would also be a good time to replace the air filter if you have not done so lately. With the air intake assembly out of the way, you now have clear access to the top of the valve cover. Along either side on top of the valve cover you will notice three black modules each held in place with one 10mm bolt with a small wiring harness connector attached. These are the coils (one per plug), and the spark plugs are located underneath. Disconnect the wiring harness connector and remove the 10mm bolt. Pull straight up on the coil and it should disconnect from the spark plug. Look down the hole and you can see the top of the spark plug 5 inches down. Using a 5/8 inch spark plug socket with a rubber 'holder' inside the socket to hold the plug, remove each plug. I had to use a 10-inch ratchet extension to provide sufficient clearance. I know it sounds goofy using a standard size socket on a metric car, but it is what it is. I make sure I get each coil back to its original location, but it really does not matter as they are all the same. Since the heads are aluminum and the spark plugs are stainless steel or monel/nickel, you have to be careful not to ruin the threads on the heads. I ONLY remove the plugs when the engine is cold. Apply some high temperature anti-seize only to the threads on the new plugs and install to 18ft-lbs of torque. Slip the coil back in place, attach the connector, install and tighten the bolt and you are done with that plug. Repeat for each plug. Re-install the air intake assembly and snap down the two latches and you are through with that side.
The driver's side is more difficult as there are things in the way. I had to remove one bracket (held in place with 2 12mm bolts) and disconnect a rubber hose underneath that bracket (it just slipped off with little effort - no tools required) in order to provide sufficient room to remove the coils. This is not as bad as it sounds, and I had both removed in under 2 minutes. Now you have access to the coils and plugs and can repeat the process. Go slow, take your time, don't get anti-seize on the plug firing tip, use a torque wrench if you have access to one. Replace the hose and the bracket and you are done.
Total time is 1 hour if you are not mechanically inclined, 30 minutes if you are.
SOURCE: replace front brake pad 2003 toyota 4 runner
Diagram is unnecessry.
Pull both front wheels
Work one at a time leaving the other for reference
Find the retention spring ... its a paperclip thickness wire spring... dislodge center retention loop and undo from both ends which engage brake pad retention rods.
Pull the rods out
Pull the old pads out... laying everything on the ground
Use scrap wooden wedges to pry between the rotor and the caliper ...inside and out until the calipers are fully withdrawn. Use the new pads to measure if they are far enough back.
Note... the brake fluid will have dropped in the master cylinder over many months of wear... do not fill it. When the calipers are pushed back they will fill the reservoir again... one wheel at a time.
Be sure to identify the correct pad based on what you took out and what is on the other side (if you screwed up the layout)
Make sure to take the old antisqueek backing plate from the old pad and place it on the new pad. They don't use lubricant on these anymore.
Replace the pads... the retention rods... then the retention spring
Do the other side
Then progressively step on the brake peddle until full tension is felt
Check the master cylinder reservoir... probably needs no additional fluid.
New pads will register in existing ridges in each disc in no time at all.
You should check the discs to see if they need to be replaced during this operation...using some calipers
SOURCE: changing spark plugs in a 2004 toyota 4runner
check www.4x4wire.com i was just there looking for the same thing and found step by step directions on how to do it
SOURCE: Toyota 4runner gate window, wiper, and keyless entry not working
make sure the back window is all the way up then try the wiper, if it still does not work then it is a sensor for the rear window (about $30.00) if you installed it yourself
I’m happy to help further over the phone at https://www.6ya.com/expert/john_5260ce46f2f674cc
SOURCE: 1987 toyota 4runner tailgate window stopped working
If you haven't already done so check fuses and all the obvious stuff first :P
The switch inside the truck and the key switch on the tailgate work from a ground source. That ground can be interrupted by 2 safety switches relating to the tailgate window operation. 1 safety switch is the top removal switch which is depressed when a specific bold that holds the fiberglass top is installed. It is located behind the drivers side trim panel in the cargo area about half way back from the rear seat. When you take that bolt out and take the top off you cant roll the window up. This is however most likely not the problem.
The second switch is actually inside the drivers side tailgate latch. This was the culprit when I had the same problem and seems to be a likely point of failure. First off, remove the switch for the window from the center consol and check the connector for ground on the common contact (usually center but check them all). If there is no continuity to ground then this is a sure sign that one of those safety switches is faulty (assuming no broken wires). You can check the first switch but is most likely a waste of time.
To remove the tailgate latch you first need to get the tailgate open and if your window doesn't work it needs to be rolled down first. Using any small gauge wire attach one end to a ground source and touch the other end to the connector contacts for the window switch you removed. One of the contacts to ground will roll the window down, the other up, and the third will do nothing that you will notice.
After the window is down, lower the tailgate and remove trim panel and everything else necessary to get to the drivers tailgate latch and remove it. It has a 2 wire connector attached to it. After it is removed place a jumper in the 2 wire connector and test your console switch for ground, if it has a ground then that was your problem.
I cant remember if the glass was in the way but if it is you can roll it up with the tailgate down with the jumper method above just have a friend lift the glass as it comes out so it doesn't damage or scratch it and have it braced with a table or something. Don't let the glass out with the tailgate down without helping it, it isn't designed to do so and could damage stuff.
When I pulled the latch and took it apart it was full of mud, I even removed the very tiny switch from it and took the switch apart to clean it. That part was very difficult because the parts were very small and not meant to be pulled apart very easily. The little contact was no larger in daimeter then a #2 pencil lead and only a 1/4" long and spring loaded when you open the switch. I cleaned everything, put it back together and it worked great.
That is until now, 2 years later it started doing the same thing again. I took great lengths in sealing everything to keep mud out and everthing and it only lasted 2 years, oh well. In short, it may be expensive but a new latch assembly might be a good idea. I have to do this job soon myself... again.
I would check for this problem before looking at the relay control because the relay control is a little more difficult to get to.
