Have been given the Noma Moonrays 9 hour lowvoltage lghting system for the yard. Cannot figure out how to set the timer. Has a dusk/dawn as well as 9 hour setting. Thank you for any help.
You have the 9 hour 200 watt Moonray.
Copy following link to identify timer and see basic instructions by pushing button and cycling throught choices.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Power-pack
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: instructions for NOMA N1507 timer for programming -pls.
N1507 manual:
http://waterheatertimer.org/pdf/N1507-programmable-outdoor-timer-manual.pdf
Add a comment and let me know if these instructions are accurate
SOURCE: lost instuctions to program Model N1560 Noma outdoor timer
Use the top button to adjust the current time & then push the bottom button once to save. Next is the time you want the lights to turn on & push bottom button once to save. The last setting is the time you want the lights to turn off. Don't forget to use the . (period) indicator for the pm setting. (I had the same problem and had to search the net to find someone else who had posted the instructions.)
SOURCE: Programming my Noma photoelectric switch
I would like to figure out out to program my NOMA photo electric switch Model Number N 1502
SOURCE: Noma Timer Model #ET525C - Require Instructions
ET525C is UPM timer
http://waterheatertimer.org/UPM-timers-and-manuals.html
UPM ET525C Manual
http://waterheatertimer.org/pdf/UPM-ET525C-heavy-duty.pdf
Instructions are 14 pages. It is impractical to re-write 14 pages of instructions.
If you have a problem, add a comment and say exactly which programming you want to set, and I will respond.
-Timer can be programmed for ON and OFF times, for Dawn-Dusk, for Countdown, for Daylight countdown, for daylight saving, and for Random. Each different programming option has 8-12 steps shown in manual.
SOURCE: I have a Noma Timer model number ET420C, could you
UPM shows ET420C timer
Manual for timer
http://waterheatertimer.org/pdf/ET420C-Manual.pdf
