Televison & Video Logo
Jeff Roike Posted on Sep 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there a coaxial input on this tv? - Polaroid FLM-3701 Television
C. David Graves
Level 2:
Novelist:
  • Expert 69 Answers
  • Posted on Sep 28, 2015
C. David Graves
Expert
Level 2:
Novelist:
Answers
69
Questions
Helped
52796
Points
198
The Polaroid FLM-3701 does not have a TV tuner. It is really a monitor, rather than a TV. You can not connect it directly to an antenna or cable. To watch cable TV, you need to connect to a cable box. To watch antenna TV, you need to connect some intermediary device, like a converter box.
Also, the FLM-3710 does not have an HDMI input. So you can not connect to any device that has only HDMI output. Some cable boxes, blue ray players and game systems are HDMI output only. The inputs on the FLM-3710 are component, composite, VGA and HDMI. Hopefully you can get a cable box with component output.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 31, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
262
Points
No because it is a monitor only; meaning it does not have a TV tuner of its own.
Where is the coaxial output on the LT-2722 twenty-seven inch LCD TV from Norcent
Many new TV's do not have a standard coaxial input anymore. The industry has moved on from that and you might have to get an external tuner to get an input like that. I found an old review from 2006 and it shows the antenna input on the bottom side where the power cord plugs in. http://www.geek.com/xyzcomputing/norcent-lt-2722-27-inch-lcd-tv-571351/
How do you hook up cable box using coaxial in hdmi out
If your cable box has an HDMI OUT connector you simply connect the HDMI cable to the TV and the coaxial cable from the cable company to the coaxial input on the cable box. Then select the HDMI input on the TV that matches the number of the HDMI input port you chose on the back of the TV.
2answers
My cable box is hooked up but no signal can u tell me whats wrong
If you hookup your TV directly to the coaxial cable, bypassing the cable-box, do you get a few channels? If so, then the coaxial cable is carrying a signal, which is good.
How are you hooking the output from the cable-box to the input(s) on the TV? Coaxial output port on box to coaxial input port on TV?
Red/blue/green "component" outputs on box to matching inputs on TV? Red/White audio outputs on box to red/white inputs on TV? HMDI output from box to HDMI input on TV?
You have to "tell" the TV which of the inputs:
* coaxial (with TV set to Channel 3 or 4)
* component
* HDMI
to "listen" to.
How do you hook recorder up to tv and dvr cable box
Simple. Connect the composite output from the VCR to the composite input on the back of the Presidian. Then connect the coaxial output from the back of the DVR to the coaxial input on the back of the Presidian. Then connect the coaxial output from Presidian to the coaxial input on the back of the TV. Turn everything on and enjoy! :-)
How to connect a sv5000 on a very old tv?
Does the SV5000 have a coaxial (Channel 3 or 4) output? Connect that output to the antenna input to the old TV. If your TV is so old that it has only a 300 ohm antenna input (2 screws), just use one those old adapters that has 2 scew lugs on one end and a coaxial receptacle on the other, connect a coaxial connector between that and the VCR's coaxial output.
I hava a insignia dvd receiver is-htib102731 and want to know what optical digital audio cord to buy for sound on my tv
gailsplaytim,
That really depends on what audio inputs you have on your tv. Your Insignia has composite audio outputs (Red and White) and digital coaxial and your tv most likely will have at least composite inputs.
The easiest way to connect your dvd to your tv is just to use the composite as you will not hear the difference in sound quality between the two through the speakers built into your tv.
If you want to run digital audio into your tv for a reason such as the tv's audio output is running to another device like a receiver and you want the digital audio to transfer, you need to look at what digital audio inputs you have on your tv. The only digital audio output on your dvd is a digital coaxial. You can buy digital coaxial converters online. If your tv for example has a toslink input, there are digital coaxial to toslink converters relativity cheap online
-Chris.
Can i connect my audio and video cable to a coaxial cable? so one side is coaxial cable and the other is audio and video cable one for the the wall and the other audio and video for the tv, this is beause...
U have HDMI ports,order HD from the cable or telicom compannies.Use a HDMI cable for the tv,also get HD channels.Do not have HDMI ports than ur Main signal board must replaced the Antena analog coaxial it broken.Well not able to buy the coaxial input for the antena along for part.
RCA RTD 215 audio input
After posting my question on Fixya, I went to www.cnet.com and found reviews on 3 systems $100-200 which had coaxial digital audio inputs.
1helpful
Hd tv to vcr
What model and manufacturer DVD/VCR combo are you using. if it has a HDMI port, you should buy a HDMI cable to your combo player than to your HDTV (most don't have this High Definition port.) 6f3606c.jpg
 otherwise, it probably contains a composite port, connect the red to the red (Left) white to white (mono) and yellow to yellow (Video) than connect the wires to the matching port on your HDTV) then switch the input to AV or Composite. 9701d83.jpgb5e3eb0.jpg
If this fails, you need a coaxial cable.85dec5e.jpgconnect a coaxial cable to your player then to the coaxial port on your tv. change the input to "either Coaxial, Cable 3 or any input that sets it to coaxial input.
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
