I hit the delete all button and I didn't mean too, can you help me?
You can recover files with some data recovery tool, see this step by step guide:
Recover deleted files from PNY memory card
hope this helps.
You can use third-party software Kernel for Digital Media Recovery Tool. This software quickly recover all lost deleted photos. visit here :
Memory Card Data Recovery
You can use recovery tool to restore your wedding pictures easily. 4Card Recovery is a useful recovery software. Have a try.
Try recovery tools like 4Card Recovery. How to Recover Photos Videos off SD Card after Formatting Unformat SD...
I've used Recuva (free download). Do a thorough deep scan and save to another drive. Very simple to use as long as you have not reused same physical space on card.
http://www.piriform.com/recuva
SOURCE: How do I delete the pictures from my PNY Attache 4G memory
insert the card into your computer. The best way is (dependding what os you have...) open my computer in xp or computer on vista. Now right click on the drive your card is in now left click on format. It will ask you if will want to delete all the files click yes and your done it's been reformatted like it is a brand new card.
Warning once you format the card you can not undo what has been done so make sure you really want to delete your card.
Good luck and take many more pictures.
SOURCE: my pny 2gb micro sd memory card is
First check to see if it has a slide bar any where on the card itself to lock/unlock.
second download and install Sony EzRecover....
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Sony-EzRecover.shtml
and use it to format the card (which will erase all data).
If that doesn't work select Control Panel --> Administrative Tools--> "Disk
Management. Select the micro SD drive and click Delete. Right-click
on empty drive and select New Partition.
SOURCE: PURCHASE THE PNY 4GB MEMORY CARD
I have the same problem with the card, my cannon camera, and my gateway laptop. From what I've learned in the past ten minutes, the card is SDHC and my devices are not. The card is not able to dumb down and I am returning it to Best Buy. The HC in SDHC is the issue from my best guess. Similar to you cannot play PS3 games on PS2. I hope this helps anyone else.
SOURCE: I cannot upload pictures/ videos from my PNY 8GB memory stick.
The newer large capacity cards in cameras designed for smaller capacity cards seem to have trouble interfacing with our computers. The best best is to get a high speed firewire memory card reader and attach it directly to your computer.
This should allow your computer to recognize your card and also allow you quicker downloads.
SOURCE: Memory card will not show up on my computer.
Verbatim compact flash card has over 200 photos corrupted files. I volunteered to take photos for local senior anniversary I was the main camera now, I have lost the content. Files are Dcim--JPO, POG and worse coded files not JPEGs and I even with trial acdsee repair I am unable to rename and restore these photo files. CVS photo was able to open some of the files with their program but advised we would need to find the proper recovery program to restore some of the files.HELP
