2006 Audi A8 Logo
Posted on Dec 27, 2008
Voice Activation I just purchased a 2005 A8 and I dont understand how the voice activation works. I get in the car and press the voice button but can not get the car to do what I want it to. It does not reconize any of my commands. Also it keeps taking me on OnStar. Why?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 15, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1038
Points
Ref: Audi MMI : The voice commands are in the Operations manual for the MMI. The precondition for MMI Voice Control is a multifunctional Steering Wheel but this does not mean the car you purchased actually has Voice control installed. The easiest way to find out all of these unknown questions about your Used Audi is take your Vehichle ID document which contains the Chassis number, to an Audi dealer. Go to the parts department and ask them to print out a list of the equipment which was installed in your car when it was Manufactured. This list should not cost you anything, but then I purchased my Audi in Europe, the U.S. has it's own bowl of soup. If it's installed in your car, then it should be activated by pushing and holding the Voice button on the right side
of your steering wheel when the Ignition key is on and waiting for a voice/beep to indicated the status of the voice command feature.
There are also preconditions for activation in the users manual for MMI. Good luck.
Anonymous
Level 1:
  • Posted on Aug 23, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1038
Points
I have a 2006 A8 and if you need help with the command say "help mmi" or when you are in one of the following modes: radio, CD, or Navigation. you can say "help ." This should provide you with all the commands the voice command can understand.
1helpful
I have a 2016 Honda Accord Sport. I have no problem answering my phone but can't get the voice activation system to work.
Since this is a new car under warranty consult the dealer, you may have a defective module or a computer flash is needed to correct a built in problem..
2005 RL Hands free link will not disconnect. No radio
I would try a hard reset. This is done by turning the key on, disconnecting the battery cables, isolating them from the battery posts and connecting them with a jumper wire. This will clear the power from all the capacitors in the audio and HFL systems and hopefully reset them. Leave the cables jumped together for 20 minutes and recheck. Make sure you have your radio and navi codes handy as you will need them to get past the anti theft functions.
I just want to know if some cars have a reset botton if you run out of gas
YES, THE ONES THAT YOU RACE IN A VIDEO GAME ONLY. THE ALSO CRASH AND YOU DONT GET HURT, YOU CAN HOWEVER GET AAA/CAA/ROADSIDE ASSIST AND PRETEND THE CALL NUMBER IS RESET BUTTON..THAT MAKE TOW TRUCK APPEAR IN 20 MINUTES AFTER VOICE ACTIVATION.
MOST CARS HAVE A RESERVE TANK OF 68KM, OR MORE ONCE TEH LOW GAS LIGHT COME ON. FYI
I have a Rosen Piranah Navigation/CD/DVDEntertainment system. Everything was professionally installed over two months ago. All was working well today until I all of a sudden lost audio/sound. What ha
if its only 2 months old take it back you get a years warenty with audio equipment and fitting dont take no for an answer get them to put it right
The light for the bluetooth system in our 2012 VW Sportwagen isn't turning on, and the phone is not showing up on the multi-function display in the gauge console. It will not power up with buttons on
Check the manual.There should be instructions on how to pare the 2. Make sure Bluetooth is on in the phone settings and is also abled to be discovered.
2005 Acura RL When I start up my car theGPS
Your best bet is the dealer, It may be a recall or a technical service bulletin. Dealer or electronic specialist.
2answers
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you an Audi Expert? Answer questions, earn points and help others
