My equator ez2500 washing machine is leaking water from the bottom...I checked and it's coming from the white pump thing with a small fan attached to it...where can i get this part to fix my washer..ps it's an apartment size washer.. thanks
I've had my equator super 4400n for a year. Started leaking and I noticed the overflow hose was split. I replaced the hose and it's still leaking. Only leaks during drying for some odd reason... I will post more after I dig into it some more.
Please contact Appliance Desk or Equator to get Tech Support & Parts for your machine. their contact no is 713 464 3422 or 713 464 3858 Ext 186 / 175
SOURCE: Washer/Dryer not drying
is your dryer a conderser type
does it have a tank that you have to empty at the end of cycles
if it does the filter that condensers the water from drying cycle
if that is blocked it will not work
SOURCE: washer is leaking
Hi just went through the same thing... so you can tell if it is the pump take off back support... run it through a cycle and when it drains you will notice the pump turn on and if the water is leaking from the middle of pump the housing is worn out. You can get the part from appliance desk. Equator sold all of the repair stuff to them . [email protected] ask for Garry don't be suprised if the part is backordered from Italy. It took me 6 weeks to get my part. Good luck happy new year
SOURCE: The machine will fill with water and run through
Have exactly the same problem. At first thought it was broken drain pipe--as I found broken drain pipe searching for a fix for this--coincidence? Anyway, drain pipe fixed, and unit still will not enter spin mode. When unit gets to spin mode, there's an audible click (solenoid), and the unit will not spin or drain the water.
All else is working fine.
What part should be replaced?
SOURCE: hi i ahve an equator ez3600 washer dryer unit
It may have been leaking from the drain pump and you may want to check if it the drain pump by opening the back panel and checking if it leaks just when the drain pump starts to function.
SOURCE: i need a diagram of an Equator EZ3612CEE door
While you may have removed the door with the hinges from the cabinet the nuts may have fallen down on the unit.
You may want to open the back panel or the bottom panel and try searching for the same, in case you need assistance mounting the bracket back on the cabinet once you have the nuts do let me know.
