I had my Omega Lexicon successfully hooked up to my 2006 Mac book Pro and Roland Fantom 7x...and had made some recording demos on Garage band. THen I took a year off, bought a new 2007 IMAC and now can't the computer to accept the Omega CD software. The Operating system is Leopard. I install the CD and when it says CLICK ON CUBASE to install the program, it says, "error" or if I click USE LEXICON INSTALLER, it says> "Lexicon INstaller is locked." what do I do? I tried looking for drivers, but did not seem to find ones that help. Thanks.
SOURCE: installing omega lexicon desktop recording studio
Yes it's extremly tempramental, just keep repeating the proces it' will work eventually!
SOURCE: Blue Screen of Death when running MIDI input to Lexicon Omega
I tried the above - works perfect!
Thanx lumps...
Thomas
SOURCE: Cubase software lexicon Lambda and IMAC
Great! Model name: iMac Model Identifier iMac7,1 Maco's 10.5.1 software. Model Name The lexicon is LEXLAMBDA # 01005169
Thanks
Bob
SOURCE: lexicon omega driver
Yes having the same problem with new driver that Lexicon put on their site 2.5 driver has screwed up everything and the soundcard is nolonger working because of this new driver even their website is down very poor avoid Lexicon Omega
SOURCE: Lexicon Omega/Cubasele4
I've had this problem and similar ones. Following these steps seems to help:
Starting Cubase before switching on the Omega.
Go to 'Devices' and then 'Device Set-up'. Make sure you're in the 'VST Audio System' part of the menu. Make sure the Omega is selected as the ASIO driver - if not, switch it. Then click on 'Set to Defaults', then 'Apply' and 'OK'.
Or re-setting the Omega sometimes helps too.
It's a pain, though.
If you had it installed on a pc then thr drivers will not be the same for a Mac OS. download driver for the operating syatem that you have, if available. If not available you cannot use it on your Mac.
http://www.lexicon.com/downloads/index.a...
