I have a gleb30t8csa Frigidaire double convection oven that is about 5 years old. Today My mother was baking and all of a sudden would not heat over 295,
Any suggestions?
SOURCE: Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
SOURCE: installing a new frigidaire double oven
there should be some screw holes along the sides installation instructions should have come with the unit but if they did not can get them here http://www.frigidaire.com/support/ResultsPage.asp?strModel=PLEB27T9DC&User=&Search=Search
SOURCE: Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
SOURCE: how do I remove the oven door of Frigidaire Model
Hi.
You have to open the door all the way through.
Then remove the two locks from the hinges.Pull the tabs out, help yourself with a screwdriver.
Grab the door firmly on both sides, pull up the top of the door and slide it out.
Here all diagrams and parts for your appliance.
Regards.
