Clothes are very difficult to iron when they are fully dry or over-dried in the dryer. Over-dried clothes are resistant to reshaping, which it exactly what ironing is. Removing clothes when they are still slightly damp will make ironing much easier. If you line-dry your clothes, bring them inside to iron when they are not quite dry.
The fine fibres at the surface of linen stand up like the bristles on a brush. Light coming into the fibres gets trapped. When you iron the linen, you flatten the fine fibres. Incoming light no longer gets trapped in the spaces between the fibres and instead is reflected (bounced back) like on a mirror. That is why linen looks shiny after ironing. To prevent this, use a damp cloth on top of your linen when ironing. This will flatten (iron) the linen material but not compress the fine fibres. Good look.
ensure your iron steam button is not set into perminent steam function. leaving the iron with the point of the iron pointing upwards should reduce steam to the handle. also the iron may need to be descaled to ensure any steam switch funtion is not stuck in an on position.
Visual Check: 1. Do you smell burned electrical wire? If none, 2. Check the cord for damage, and the outlet for electricity ((plug in another device and see if it turns on)). If none, 3. Does the water reservoir or iron face have visible mineral deposits (i.e. need cleaning)?
Possible solutions:
1. On COLD, UNPLUGGED iron, clean working surface with non-abrasive cloth.
2. Try Vinegar & Water cleaning to remove mineral deposits (if warranty allows): Mix equal parts water and white vinegar (abt. 1/3 cup each). Pour into water reservoir. Turn on the iron with steam option. Allow to work, upright, for 2-3 minutes. Turn all controls to low before unplugging. Drain into sink ...carefully, it may be hot! Flush with plain water. Reheat iron and test on scrap cloth to clear any residue.
BE SAFE and work carefully. If iron still does not heat after thorough inspection and cleaning, the unit may need a qualified technician.
see this causes and fix it. God bless you Clean an iron:
Unplug the iron and make sure it is cool before cleaning.
Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup
vinegar into the water tank. Place the iron on a rack over a broiling
pan and set the iron to steam until the tank runs dry. Repeat if
necessary. Or follow the instructions for using a commercial iron
cleaner.
Service the steam and spray mechanism:
Unplug the iron.
Use a fine sewing needle to unclog the steam valve assembly. Also,
check the valve spring and replace it if it is broken or has lost
tension.
If the spray pump is accessible, remove it and check for leaks by
placing the spray tube in water and squirting the pump. Clean or replace
as needed.
Clean a metal soleplate:
Unplug the iron.
Use a sponge and commercial soleplate cleaner or baking soda and
water to remove dirt buildup on the soleplate. Rinse well with water and
dry. Don't use harsh abrasives or immerse an electric iron in water.
Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Leaking irons happen more frequently when performing lower temperature ironing. Minimize the chances of this happening by doing the articles that require less heat with a dry iron. When you're ready to do the articles that require higher heat settings, add distilled water to the iron after allowing it to cool first (some folks suggest using rain water as it will lack the minerals contained in the soil - where water pumped from the ground picks them up).
Distilled water is recommended by manufacturers for irons. Use of regular tap water will cause mineral deposits to form inside the iron that can build up and even clog the openings on the bottom plate. These can contribute to stains on the material being ironed, too. If you are unable to obtain distilled water, you ought to descale the iron regularly to remove deposits that will form by heating water or allowing it to simply evaporate. Distilled water lacks the minerals to be deposited by either of these situations. If distilled water is used - there is no need to empty the iron before storing. Tap water - whether supplied by the locality or a well is loaded with minerals and may be treated with fluoride, chlorine, etc. Descaling an iron is pretty straight forward - no more difficult than descaling a coffee maker. Empty the iron of any water. Partially fill the iron with white vinegar and turn on to heat. Iron and old towel or rag to allow all the vinegar to pass through the steam openings.When empty, repeat once or twice - but with fresh distilled water to flush any remaining vinegar from the iron. When satisfied that the vinegar is out, store the iron. You can purchase products expressly made for descaling irons - just like you can for coffeemakers, but vinegar is a great low cost solution that works very well.
the brown liquid is rust from leaving the water in the iron. Always dump the water out when you are done ironing. You need to run a descaler through it. you can purchase descaler online. The shutting off and on could be a loose wire.
The thermostats gone.
try using it on very cool temprature setting.
See if it lasts longer.
Not worth the trouble of replacing a thermostat.
I,d buy a new Iron.
Mike @ Compurepair.
dosen't stay hot...light flashes then when i unplug and plug back in it works for awhile
