Computers & Internet Logo
Posted on Dec 27, 2008
Can't get internet connection to my lap top.ps i have a desk top.
After connecting all the cables as intrcted in the intructions on the wireless router ultra range plus my lap top says that the inthernet does not appear to be connected properly.
  • Anonymous May 11, 2010
    Can you be more precise concerning the model ?
Anonymous
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Dec 29, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
2899
Points
29
Is your laptop wireless adapter correctly configured? It may be set to only recieve certain types of signals (802.11b, when you may beed 802.11g etc), so check if the configuration of the laptop matches the configuration of the router.
To test if the laptop can get internet at all, try to get to a wired internet line (your wireless router may have some Ethernet ports on the back; laptops usually have Ethernet connectivity), just incase your laptop is set to block all internet signals coming in.
Hope this helps!
I can't get my desk top to connect to internet it tells me my ip address is not right but my lap top goes through my desk top and i don't have any problems getting on line.
your dell needs a network adapter card or wireless card installed is that the case(look in b ack)
if no wireless, then it needs an ethernet cable plugged into modem/router from cin bell and then in back of dell
please advise your network configuration
How do I make my Brother MFC-290C printer print wirelessly? I don't have a desk top that I can attach permanently to the printer. Our computers are all lap tops. But I do have a linksys router for...
you can either purchase a new router that has usb printer support or a usb print server that can connect via a cat5 cable to the printer or wirelessly.
1helpful
How do I get my EnGenius ESR-9752 router to work with my Actiontec GT701 modem? I have a desk top computer using XP. I just bought a lap top with wireless capabilites. I want to run this system through the...
1. connect yellow cable from Actiontec to the internet port (labeled internet)
2. Power cycle the engenius router.
3. login to the Engenius and verify the status. You should an IP Address from the ISP (Internet Service Provider). If not then you will have to verify the IP address from the router.
4.Make sure the laptop the see the wireless connection.
5.Verify the "ESSID" if your router and connect.
No Internet via zoom X6 wireless router to desk top, lap top ok.
Access your zoom router by using the laptop which still has access to the router.
Your going to have to open your Wireless Network Connection Status window located under your network settings.
If you see this window your going to left click the (details) button
Now you should see a IP DNS server address
for example: 192.168.1.xxx
Type that address onto the address bar of your web browser.
it should take you to your router setup page.
There you will need to check if the lan port is enabled
Although cable to desktop connects to internet, my router from desktop to laptop via router won't connect.
Desk top to internet is OK.
How about Destop through Router connection to Internet OK?
Assuming you want to connect wireless from Lap top to Network, need to configure correctly for wireless in Router.
If you connect Lap top to router by wire and it didn't work that mean your router is bad.
I can not connect my wireless Camera to My laptop Vista
You need free Dynamic DNS service from sites like NO-IP.com
1helpful
Lan internet
the easiest way to setup internet on the laptop, is to go to control panel, and launch the network setup wizard. this will enable you to setup a new network, and scan for a local area network connection. this will also give you access to the troubleshooter. to solve any connection problems or issues, should there be any. If your using a wireless method. Your PC must also be able to transmit/receive wireless Signals. If hardwired you,ll have to use the network setup wizard, as this will auto determine I.P And any other DNS settings et,c.
Hope this Helps Mike @ compurepair.
1helpful
Trying to connect desk top computer and lap top computer
There is only two ways to possibly connect both the desktop and the laptop in the network. That is to purchase a router so you can connect them both or a route with a wireless and then the laptop (Which most new ones have a wireless capability installed) can connect wireless from anywhere in the home. If you already have a Cable or DSL Modem it may have a wireless capability. Otherwise you would have to get a wireless modem. Hope this helps. Bud
Laptop
the internet cable should be connected to the "Internet" or "WAN" port on the router. Your PC should be connected to one of the regular ports on the back of the router and your laptop can be connected just like the pc, or it can connect wirelessly.
Then you should be able to see the internet from your laptop.
Grand Canyon Tech
Grand Canyon Tech
