I don't see a "candy" model but there are some called "Jam".
If one of these is similar to your model, click on the picture of the watch, a new page will open. Under the color choices on the right side you will see a link to the Manual. The manual will have setting instructions.
I don't see your model but perhaps on of these is similar in design and operation. Click on the picture that most closely resembles your watch; a new screen will open. On the right side under the color choices will be a link to the Manual.
This manual will help
http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
I think these are the directions you need
2.0 Alarm and Chime On/Off
2.1 In Normal Display hold B-Button,and push A-Button once:
Chime will be on.
2.2 push A-Button once again: Alarm will be on
2.3 push A-Button once again: Chime will be off
2.4 push A-Button once again: Alarm will be off
2.5 Release B-Button, the Display changes to Normal Display
immediately.
Had same problem. Press and hold C (mode) until the display flashes. Then press C again (without releasing) to get to time. Press "Select" to move from sec, min, hours, days, etc. Press advance to go change the actual time.
these directions work
if you change the following:
C=C Mode
A=Select
B=Advance
Normal Time Setting
5.1 In Normal Display, hold C-Button for more three seconds
and then push C-Button once. Tuesday flag and seconds
digits will flash. Push B-Button once to reset the second
to zero.
5.2 Push of A-Button once: Minute digits flash and advance by
depression of B-Button
5.3 Push of A-Button once again: Hour digits flash and advance as above.
5.4 Push of A-Button once again: Month, digits flash and advance as above
5.5 Push of A-Button once again: Date digits flash and advance as above
5.6 Push of A-Button once again: Flag of weekday flash and advance as above
5.7 If push of C-Button during any changing time, Normal Display will be
appeared
I found users instructions on roxy website at:
http://www.roxy.com/search/index.jsp?f=Taxonomy%2FROXY%2F2818169&categoryId=2818071&f=Taxonomy%2FROXY%2F2818071&fbc=1&fbn=Taxonomy|Watches&fbx=0
We were able to program our watch completely!!!
If you look on the back of the watch that you bought on the metal plate, it tells you the style. Ours was the Roxy 70's digital watch, and I found specific instructions at (even if this is not your style, the instructions may work): http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
Possibly, you could push the hour-setting button through either the military or standard time setting, i.e., there are actually 48 "hours" you can set your watch to and you need to cycle through enough of them to reach the standard or military hour you want.
