SOURCE: grinding noise from passenger side engine
The water pump bearings could be going out and they will make a grinding noise.The water pump doesn't always leak when the bearings are going out.
SOURCE: 2006 dodge sprinter esp light on and tire spin light
Go to nearest garage and do diagnosis test and fault erase.
SOURCE: 2006 Dodge Gr. Caravan. Loud humming noise upon
Misalignment of the belt, incorrect belt, worn or loose tensioner, Too tight of an adjustment (many service centers do this on purpose so when the belt breaks in it becomes properly adjusted, I do not believe in this philosophy), The belt is actually one long belt called a serpentine belt.....
