"My archos 18b vision is not seen by my laptop or free standing computer when plugged in to usb.". Both use win7
SOURCE: Sandisk sansa e200
I had this same problem on my sansa and tryed the previous solution with no luck. Out of frustration i email the sansa technical support. Try these steps to format the player: -Turn on the player and access MENU > SETTINGS > USB > MSC - Once the player is set to MSC mode, reconnect it to the computer and open the My Computer window. - Once you see the Sansa icon in the My Computer window, right-click it and choose FORMAT - In the Format window, choose FAT 32 and make sure that Quick Format is NOT selected, then choose START -Once the format has completed, disconnect the player from the computer to allow it to refresh. If you plan on using Windows Media Player to transfer files, return to the USB menu and set the player to MTP mode. Otherwise, leave the player in MSC mode and you can now resume transferring files. Formatting your player will deleate all files but you can putt them back on!!! Best of luck!
SOURCE: how to remove write protect on my usb flash drive
I'm trying to spread the news on how I fixed mine just this morning with the same problem. I can't believe how many people have the same problem.
I have heard to format--didn't work for me. I have heard to switch the write-protection button on the side--mine doesn't have one.
I heard to make sure your mp3 is not in 'pause' or 'hold' mode--THAT WORKED FOR ME! It was so simple. I had been messing with the buttons so much I must have put it in pause. Please try it. Good luck.
SOURCE: i cant delete songs
you need to go into my computer find the mp3 and go into where the music files are you should be able to delete them from there
SOURCE: can't get the right usb connection on my mp3 to download music.
Win Xp -> Go to Start-Control Panel - System - Device Manager - Last on the list is MTP player, click on it and select upgrade driver - i will choose myself - i there will be two options ( MTP player and USB mass storage device ) Pick Usb mass storage and then OK. Then your MP3 player is visible in My Computer
