You CAN just bypass the filtration system, BUT, you're going to have mineral deposits buildup in various locations over time. If that's not a problem for you, then TAKE OFF OSMOSIS SYSTEM, and just extend the hose that goes into the filtration system---- to the hose that exits the system, connect the two, and that's it, all set. Make sure all your hose connections are secure, so you don't get leaks, or flood your floor. You could put in an activated charcoal sytem, which will take out chlorine, other chemical contaminants and give much more water per minute than a RO system, if that's your reason for wanting to remove it. You could easily use your existing RO unit, merely remove the RO membrane filter, and bypass it, and that would use all the other filters it has, without slowing the water flow excessively. Also, it will, NOT take out any minerals, or heavy metals or viruses, like the RO membrane will do, but the water flavor is more how most people like.
does removing it bypass it? I want to remove it and not replace it but still use icemaker and water in door.
I want to use the fridge without a filter... I have reverse Osmosis system hooked to it..
