The click you are hearing is most likely the start slenoid making contact, however you should short the large wires @ the solenoid to make certain the starter still doesn't run, if so try tapping the starter with a hammer to shift the comutator a litle and try to start. Even if it now starts the starter will continue to give you problems so the proper fix is change the starter
SOURCE: 95 F150 wont crank
the starter should be replaced. The solenoid is kikcing the pinion out but there is no contact being made to turn the starter motor. I have the exact same truck and before i changed the starter used the old starter tap trick. Tap the starter casing with a hammer and it should start turning again. hope this was helpful for you. Good luck.
SOURCE: 1992 Ford Taurus Starter
I believe the starter solenoid on the fords are separate from the starter. If that's the case the solenoid could be the culprit. It may also be the ignition switch ( where the key goes in) There are several connections that take place through it and contacts can go bad. Fortunately, switchs usually aren't very expensive, maybe 15-20$. Same with the solenoid. Good luck. Please rate this. Thanks
SOURCE: 1990 Ford Taurus SW 3.0L Power Problem
CHECK GROUND WIRE FROM BATTERY TO BODY AND BODY TO ENGINE
