Check the fans are running ok, and the condensing area isn't too hot. Check the door closes properly and the inside isn't blocked up with ice. If all appears ok you may have to call out a technician
I will tell you how I fixed this problem for a one time payment of $19.95. Or, go to appliancerepair.com and get the answer for free. There! That'l FIXYA.
Beverage air used R134a almost exclusively on refrigerators. The process is similiar to ac systems. You should weigh the charge in as per the data plate. Be precise as over or under charge can dramitically affect the performance of the unit. Hope this helps
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
