SOURCE: how do i inrease the number of rings
Don't know if this will work, but try the 983 feature, pw 1020000 (or 120000, or 10020000, depending on your extension numbering). Access the Mailbox menu. "Show" thru the menu until you get to "forward to" ###, then next. This should ask for delay. (to est time in seconds, multiply the number of rings by 6)
SOURCE: Need Help! I have a nortel T7316E, for some
go to tek-tips.com they have a Nortel Norstar and BCM section in there that will get you the help.
SOURCE: Nortel T3716E send calls to voicemail HELP!
Sounds like the call forward no answer isn;t set up on your extension. The first thing to do is to find out what the voice mail pilot number is. That's done by pressing feature 982. The display should say "set:xxx". The set number provided is the voicemail pilot number.
Next you'll need to enter system programming.
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number.
Enter extension number you want to change call forward no answer on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
Press the show key (top right arrow) .
The display say foward no answer.
press theshow key (top right arrow)..
The display should say none. Press the chng key and enter in the voice mail pilot number.
press the show key again (top right arrow) To review the rings til forward. Press the chng key if you wish to change the ammount of rings til answered.
Press the release key when finished
SOURCE: Nortel T7316e need to change extention # on phone
You can go to any T7316e phone and do this , press feature 983 when you see log on the screen enter 102 0000 to log on with or 12 0000 this is the default admin password for the voice mail system . it depends if you have a 3digit extension of 2 digit . when you get in you will see three options on the screen above the three buttons , from left to right it will be mbox aa and other press the mbox button then it will give you three more options again from left to right they will be add delete and change press change , it will ask for the extension number , enter the number of your extension . the thing it will ask you is if you want to reset the password , press yes and the press the the red rels button your password is now reset to 0000 . good luck .
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to
temporarily turn them off use do not disturb (feature 85, feature #85 to
turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310,
...regards John
What my first option would be is to just change the ringtone for those lines so that we do not have to turn on/off the different lines every am/pm as the businesses in the building change. It would be easiest for us to just set different ring tones if this is possible.
