language preferences are usually very early in the set up screens, if you can't toggle it back to English using google translate to help, look for a reset to defaults, default language is usually English, but then you will have to set all your other preferences again: https://translate.google.co.uk/
The first thing you are going to need to do is to take a look at the manual for the phone in English (if you can't read German.)
Then, you'll need to view an owner's manual in German - to compare the directions. And, third, you'll probably need an online translator to translate German to English.
You will have to check 2 settings. First one. Tap on the screen.
Tap on change preferences. Tap on the arrow 3 times. You should be on
page: Preferences 4 of 6 by now. Tap on change language. Tap on English
US. Tap on Yes.
Since its in german.. You may need to use google translate to translate the german to english just so you know what screens in german match with the screens listed above.
Try this site to translate what is on the screen then you can select the options to change the language back to English. Set the translation from German to English.
The easiest way to fix this is through the Apps menu. Hit the apps key, then scroll down until you see any language(espanol, Deutsch, etc.). It should give you the option of switching to either that language or restoring to English. I just tried this on a calculator that was set to German. I hit Apps and scrolled down until I recognized the option for Spanish, and it still worked. It let me switch back to English. Hope this works for you.
u need to go to start>settings>system>regional settings andthen set ur device language to english if u want to make it completeenglish OS is that u mean ? then pls download updated English ROM fromwww.htc.com and install it as directed
i can help u more in this if u want pls rate me fixya if i solved ur problem
Thanks for getting back so quickly- I have already solved the problem so thanks anyway! I just had to install it with the CD. and followed the prompts . It was all installed in english. :-)
