This is a wireless headphones and base unit to connect to tv/laptop ect, inhereted the unit looks ok replaced batteries headphones but not obvious to replace base unit batteries then need charger??
Not all rechargeable batteries will work instead of original batteries. The right battery should have metal body and not, as some batteries, isolated bottom part (-). Such batteries (which will not work) have a isolation ring around bottom connector. Philips has some kind of electronic check if bottom part is connected (integrated with) sides of the battery. So sides and the bottom of the right battery should be a sort of a can. Check the original battery to understand better what I am trying to explain.
SOURCE: Not working
Check if the power signal in the base turns on. If not two things can be appening. The base or it's transformer is damaged, or the output jack of you soundboard is dead. Check the sound form the soundboard with some regular headphones to find the source of the problem.
Make sure that the base and the wireless phones are on the same channel and you batteries are fully charged.
SOURCE: how do I replace the
i got a problem too with my SBC HC 135. I never use it before, i found it in my brother's cabinet. I tried to connect the adapter (which is have 5(if im not mistaken) red lights) to the socket. and all the lamps are lit. then i tried to turn on the headphone, but the lamp is not lit. i got a little confuse about how to use this thing. What should i do?
