Question about Sony STR-DE425 Receiver
Locating fuse in sony str-de425 receiver - Sony STR-DE425 Receiver
5 Suggested Answers
SOURCE:
  • 85 Answers
SOURCE: operating instructions for sony str-d565 receiver
this is a link just make sure to disable protected mode in internet explorer sometimes it has problems with links
http://www.docs.sony.com/release/STRD665.PDF
Posted on Feb 23, 2009
SOURCE: I have a Sony STR-D565 Receiver. I bought new
I resently hooked up my sony std d 565 reciever for 5.1 speakers and I keep hearing beeping, what is wrong?
Posted on May 01, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: My Sony STR-DB1070 receiver recently
their are fuses, inside the unit, by the power supply area (transformer)
Posted on Dec 19, 2010
dunnbiker
  • 8546 Answers
SOURCE: Sony Stereo Receiver - STR-DE425 Loud
Toggling power on and off is NOT a good idea, nor does it ever really fix anything.
Does the TV affect the receiver even if you have other sources selected or speakers disabled?
Establish if the TV connection or lack of it affects the problem by disconnecting one cable at a time (I have no idea what cables you use) to see if the self-protection is caused when the TV is turned On. Prove that each cable is or is not involved with glitching the receiver. If it still pops after the TV is completely floated from the receiver, consider a power surge as the culprit. Maybe you need to place the receiver on a power circuit that isn't shared with the TV.
Oh, btw, you're not drawing power from the convenience outlets on the reciver for anything that sucks up a lot of juice, are you?
Posted on Mar 24, 2011
I have shorted left speaker output by leaving the speaker unplug...the two wire shorted together and blown something, someone got an idea of witch component i should replace? thx
Probably took out the output transistors for that channel. Is the unit dead now? Usually in these models, if the outputs go, it takes out the main power fuse.
Apr 08, 2013 | Sony STR-DE425 Receiver
Sony receiver keeps blowing 5 amp fuses
You have shorted output transistors in the amp that need to be replaced.
Feb 14, 2013 | Sony STR-DE425 Receiver
I have a sony str-de 405 recevier . how do i connect a subwoofer to it .....
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DE405-Receivers-manual/id/387bh944/t/2/
and refer to the manual that should have come with your unnamed subwoofer.
Mar 21, 2011 | Sony STR-DE425 Receiver
Sony receiver made pop noise and all sound systems went mute.what are my options? STR-DE425 sony receiver with surround sound, dvd player,cd player and tv all connected thru receiver...
It sounds like the output ic's may have failed, because of the complexity of system I would have a professional come and look at the unit for an evaluation, chances are he will need to take it back to the shop for service.
Dec 30, 2010 | Sony STR-DE425 Receiver
How can I use digital media port adapter TDM-iP50 with an older Sony STR DE 425 receiver's RCA inputs? Is there a conversion cable--dm port to RCA?
The dm port Can't you just pull the audio from the iPod from its analog headphone jack with an adapter? They're common and cheap.
Dec 29, 2010 | Sony STR-DE425 Receiver
Hooking up amps
kolko glup trebas bit? otput iz DVD u input u sony video, output iz sony video u tv
Dec 05, 2007 | Sony STR-DE425 Receiver
Protection error
Your speakers or the wiring to the speakers shorted out, and a fuse inside of your receiver is blown. You can purchase a new unit or attempt to replace the fuse yourself.
Nov 24, 2007 | Sony STR-DE425 Receiver
Stuck in protect mode
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Nov 23, 2007 | Sony STR-DE425 Receiver
Sony STR-DE425 Receiver Logo
69 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
