When I turn on my HP Compaq Presario SR1650NX unit seems to be booting up ok fans and lights come on but the monitor stays blank, blue screen for a few seconds, then turns to black. Connected a known working monitor to pc and got the same results. Could this be a video card issue?
SOURCE: Compaq Presario SR1650NX will only
DO one thing remove the RAM from the slot , then insert it again, then check
SOURCE: My Compaq Presario SR1650NX wont boot the light in
refer to the users manual, or download if possible.
Yellow/Orange could mean that the computer is In Hibernate/Sleep Mode et,c. usually restored by pressing certain keyboard keys Or pressing and holding the power on button For 4 seconds or more.
Other Possibility ( graphics/VGA driver or device, Corrupt Or missing )
You could change the graphics card, Or remove the motherboards Cmos Battery, for 10 seconds, which will restore the Computers Bios, default settings.
Mike @ compurepair.
SOURCE: Display does not work (blank screen) on Compaq CQ60-DX214
1. try reloading ur OS (Windows)
2. check ur RAM
SOURCE: wiring diagram for a HP Compaq Presario SR1650NX
There isn't one, there's no need for it: the plugs can go only in their correct locations and positions. The only thing you must be careful is to put the SATA hard disk cable in the first SATA connector.
SOURCE: Black Screen Compaq Presario
Do you see the BIOS splash screen or anything?
Try booting into safe mode by pressing F* as soon as you power on the computer. If the monitor works, then it is a bad driver. Roll back to a previous restore point, boot to last known good coonfiguration. Last Known good configuration is available from the same as the safe mode screen.
If this is helpful, please comment and rate. Have any other questions, please let me know.
Oz
